Plx M500 Map reading
Old Apr 1, 2008 | 07:21 PM
roachsboosted16's Avatar
Default Plx M500 Map reading
i recently installed a m500 wideband gauge/ datalogger, i got it up and running and i have 6 gauges on my computer wirelessly sent from the unit. rpm, speed, tps, iat, and map. on the map gauge im getting readings such as 12-15. would any of u honda-teckers knw what units this reading is in? hg? bar? etc.
Also what shude ur afr readings at idle be?
at idle mine are 18-19-lean, at high rpms and boost its 14-15. good or bad?
Modified by roachsboosted16 at 8:26 PM 4/1/2008
Old Apr 1, 2008 | 07:35 PM
mn_babyboy's Avatar
Default Re: Plx M500 Map reading (roachsboosted16)
It should be 14.7:1 at idle and WOT should be around 12.5:1 to 11.0 turbo cars. some Are as rich as 10. It might be your m500, because your motor will blow after 14-15 afr WOT.
Modified by mn_babyboy at 4:20 PM 4/2/2008
jonman27
Oct 22, 2010 01:25 PM
Running925
Nov 14, 2006 07:57 AM
IVI
May 24, 2005 03:47 AM
eightvalver
Aug 23, 2004 08:41 PM
meanteg
Jun 26, 2003 04:56 PM
