boosting a stock bottom h22?
Old Apr 7, 2008 | 12:57 PM
eg_h22's Avatar
From: Beautiful beaches, skies, and ladies. No worries(.) @ the OBX, NC
Default boosting a stock bottom h22?
want to see if you who have boosted or are boosting a stock bottom h22 would share your experiences?
what was your setup?
Is it worth it with low boost?
Old Apr 7, 2008 | 02:12 PM
deucedeuceEK's Avatar
Default Re: boosting a stock bottom h22? (eg_h22)
my experience turned sour quick. Their time bombs without a timer. Just like anything else tho, some people have great luck and others dont.
Old Apr 7, 2008 | 06:14 PM
Schister66's Avatar
Man U FTW
As with all stock block dual cam Hondas, if you keep them in the ~300whp range and get a good tune, you should be fine. My 315whp stock block lasted 2 years before a spun bearing (due to lack of oil because of an unrelated oil leak) stopped it in its tracks.
Old Apr 9, 2008 | 11:07 AM
eg_h22's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">As with all stock block dual cam Hondas, if you keep them in the ~300whp range and get a good tune, you should be fine. My 315whp stock block lasted 2 years before a spun bearing (due to lack of oil because of an unrelated oil leak) stopped it in its tracks. </TD></TR></TABLE>
What kind of driving did you do? Were you easy on it or what?
Old Apr 9, 2008 | 11:09 AM
eg_h22's Avatar
Default Re: (eg_h22)
anymore experiences? Good/Bad?
Old Apr 9, 2008 | 12:04 PM
extralargenog's Avatar
Stock block H22a 18psi 340WHP... BEaten eryday...
no issues... as long as the ringlands dont get trashed by detonation (read tuning) youll be ok.
Old Apr 9, 2008 | 12:19 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_h22 &raquo;</TD></TR><TR><TD CLASS="quote">
What kind of driving did you do? Were you easy on it or what?</TD></TR></TABLE>
I beat the living hell out of that car on a daily basis. It saw full boost at least once or twice every time i drove it. I also tracked it twice.
Old Apr 9, 2008 | 03:54 PM
98vtec's Avatar
moderator emeritus
stock h22a4 with 100k miles
turbonetics kit, t3/t4 unknown trim, 5 psi, Crome Pro. Conservative ignition timing.
Old Apr 10, 2008 | 12:53 PM
eg_h22's Avatar
Default Re: (extralargenog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extralargenog &raquo;</TD></TR><TR><TD CLASS="quote">Stock block H22a 18psi 340WHP... BEaten eryday...
no issues... as long as the ringlands dont get trashed by detonation (read tuning) youll be ok.</TD></TR></TABLE>
now this is what I like to hear ... thanks bro
Old Apr 10, 2008 | 12:55 PM
eg_h22's Avatar
what about going boost with blox B cams? what would I have to look forward to then? I'm already running these is why I ask...
Old Apr 10, 2008 | 01:45 PM
Scheizty's Avatar
The stock cams in the h22s are actually very decent. You won't find much increase when you boost as compared to other upgrades. If you don't have the cams already, hold off or invest elsewhere.
Old Apr 10, 2008 | 03:00 PM
ozzyman's Avatar
Default Re: (Scheizty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scheizty &raquo;</TD></TR><TR><TD CLASS="quote">The stock cams in the h22s are actually very decent. You won't find much increase when you boost as compared to other upgrades. If you don't have the cams already, hold off or invest elsewhere.</TD></TR></TABLE>
Very true. Jason at Rage performance (now Whitfield Racing) was running stock cams on his 725whp H22 turbo. That must say something.
I was running 6psi on stock block at 250whp. Ran great up until I boosted in 5th gear and blew my ringlands. The ringlands on the H22 pistons are the weakest part of the motor when it comes to boost. Hope that helps.
Old Apr 10, 2008 | 04:17 PM
Default Re: (ozzyman)
they fall off above 7200, but thats what ebcs are for... ramp that boost in... LOL.
Old Apr 10, 2008 | 04:25 PM
Garage 808 Hatch's Avatar
we did one, over a year so far on 312whp on an hx35
Old Apr 10, 2008 | 06:30 PM
Runnerdown's Avatar
Default Re: (Garage 808 Hatch)
We have done a few and they held up great. 9-10 psi and around 300whp. One of them I took apart to have sleeved and get a bigger turbo and it still looked brand new inside. I think the h22 is built well with strong parts from the factory. No reason for a well tuned and maintained engine to last a long time making good power.
Old Apr 10, 2008 | 07:07 PM
Default Re: (Runnerdown)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Runnerdown &raquo;</TD></TR><TR><TD CLASS="quote"> I think the h22 is built well with strong parts from the factory. No reason for a well tuned and maintained engine to NOT last a long time making good power.</TD></TR></TABLE>
there fixed
Old Apr 11, 2008 | 06:30 AM
Runnerdown's Avatar
thanks that what I meant
Old Apr 11, 2008 | 09:48 AM
eg_h22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extralargenog &raquo;</TD></TR><TR><TD CLASS="quote">they fall off above 7200, but thats what ebcs are for... ramp that boost in... LOL.</TD></TR></TABLE>
Im sorry... but what are ebcs?
Old Apr 11, 2008 | 09:49 AM
eg_h22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch &raquo;</TD></TR><TR><TD CLASS="quote">
there fixed</TD></TR></TABLE>
Fixed?
Old Apr 11, 2008 | 12:16 PM
ebc= electronic boost controller
Old Apr 11, 2008 | 05:08 PM
Fixed?</TD></TR></TABLE>
read what he typed, then read what i changed in it. i added a word that made it say what he meant
Old Apr 11, 2008 | 09:46 PM
borat's Avatar
Been running 7 psi for about 2 years now, ~30k miles, driven fairly hard, street tuned myself. I haven't dynoed it yet, but I expect it would look very similar to blake's graph above. The key is tuning. With a good tune, you can get a little over 300hp reliably on the stock block. Don't cheap out on the tuning components, that means get the right injectors, a wideband, and a tuneable ECU, and you will be fine.
Old Apr 13, 2008 | 12:59 PM
eg_h22's Avatar
Default Re: boosting a stock bottom h22? (borat)
Old Apr 13, 2008 | 03:35 PM
17 psi Stock from pan to cover
tq was 284 at the 321WHP
Old Apr 14, 2008 | 11:41 AM
eg_h22's Avatar
Default Re: boosting a stock bottom h22? (extralargenog)
nice ... what kit and tune are you running?
what would be a good cheap kit to start out with on low boost and still make around 300whp? If any...
