Devcon filled blocks
Old Apr 1, 2008 | 06:54 PM
civicjoe's Avatar
Default Devcon filled blocks
Devcon filled D16 block. Block is filled past the water pump port with sugar, then filled with devcon f-2 liquid aluminum. Suger is washed out and holes are drilled in the devcon to allow water to pass down.
The supposed benefits over a block guard are that it supports both the top and middle of the cylinders rather than just the top. A member on HMT said that his machinist did a bore job on a devcon filled block and said that it eliminated any cylinder walk when he bored. Also is supposed to help eliminate any cylinder flex/movement which allows the stock sleeves to hold much more power.
For those that are knowledgeable or have experience with this, is this more of a race only application or something that I could use on my DD? My setup is going to be D16Y8 Turbocharged with forged internals. Still unsure on what power levels are going to be safe for a very reliable DD. Discuss please and if you have experience with this please speak up.
THanks
EDIT: grammar
Old Apr 1, 2008 | 07:26 PM
CoreyR's Avatar
Default Re: Devcon filled blocks (civicjoe)
the HMT member youre talking about drove the car every day with the devconed block until he cracked all his sleeves. take that for what its worth.
no reason to devcon a D16 they dont seen to crack sleeves as easy as a b series.
Old Apr 1, 2008 | 08:27 PM
Schister66's Avatar
Man U FTW
Oh, i miss seeing Josh around....
Old Apr 1, 2008 | 08:36 PM
DaveF's Avatar
Default Re: (Schister66)
he is funny as hell.
Woojen
May 21, 2018 12:34 PM
guy_from_nerk
Jul 28, 2013 12:25 PM
calib17a
May 27, 2004 08:43 AM
92BlackSi
Aug 31, 2003 08:41 AM
4doorH22
Mar 9, 2003 01:26 AM
