white smoke
Old Apr 3, 2008 | 09:25 PM
2000civic ex's Avatar
Default white smoke problems....
well i just installed a brand new turbo into my car, and noticed that it smoke white sometimes, when i boost, it usually smokes sometimes. checked the pipes, no oil or anything, coolant level is fine? can anyone help me out on this....
Modified by 2000civic ex at 11:29 PM 4/5/2008
Old Apr 5, 2008 | 05:55 PM
Default Re: white smoke (2000civic ex)
help me out someone?
Old Apr 5, 2008 | 06:27 PM
H22Luda720's Avatar
Well without looking at the car i can tell you that:
White = Water/Coolant
Blue = Oil
Black = Fuel Rich
Is the turbo water cooled?
Did the car sit for awhile & possible water collected in exhaust system burning off?
Old Apr 5, 2008 | 06:28 PM
siblues's Avatar
Well the question is really open ended have you tried checkin nthe oil drain to see if its kinked or not draining right.Maybe do a compression test to make sure its not the motor.When does it smoke and more info will help.
Old Apr 5, 2008 | 09:07 PM
Default Re: white smoke (siblues)
yes it is water cooled, i checked if there was oil in the reservior, none. checked the dipstick if it coolant in it, none. doesn't overheat. it smokes when i am driving it. not when i start it up. spark plugs had no oil on it or detonation. Saw someone oil where the intake elbow connects to the turrbo. found a little oil underneath. I am running out of idea's. thought it might be the head gasket but don't see any visible sign of it being there. can't it be because the turbo is still new and coolant is not burning well in the turbo? i don't know, help me out people
Old Apr 6, 2008 | 05:31 AM
LudeNsoL's Avatar
i had the same problem its doing that cause of the turbo wat kind of turbo r u using?
Old Apr 6, 2008 | 06:43 PM
Default Re: (LudeNsoL)
i am using a edelbrock performer x kit, so i am using a gt28r turbo, but the turbo is brand new, has less than 50 miles. also would the smoke affect my performance, i moticed when i step on the gas i see it go to 6 lbs of boost but it feels like it is not pulling as hard as it used to be?
Old Apr 7, 2008 | 02:17 AM
Default Re: (2000civic ex)
do you think it is a weak headgasket?
Old Apr 7, 2008 | 07:51 AM
95jeremie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civic ex &raquo;</TD></TR><TR><TD CLASS="quote">do you think it is a weak headgasket?</TD></TR></TABLE>
so you need to give more info about your setup
motor?
miles?
built or not?
tuned? with what?
what I'm getting at is the head might be lifting while your in boost.
do you have head studs?
your only running 6lbs? or is that all you get?
from the sound of it you need to go get it tuned and get some head studs
Old Apr 7, 2008 | 02:33 PM
Default Re: (95jeremie)
d16y8 motor, 115k miles,running on stock internals,uses a edelbrock turbolink piggyback ecu, taht came with the kit since it was used for stock internals. i can get 14lbs of boost but check engine light comes on. i put it on to 6 lbs because i mostly use it to daily drive. i don't have head studs, talked to a very reputable mechanic, he said that maybe there is coolant in my exhaust pipe or old coolant, and just need to be burned off. I am running a straight downpipe. help me out someone. hope this helps
Old Apr 7, 2008 | 03:36 PM
cjordan's Avatar
are you running a stock map sensor?? unless i am terribly mistaken if your running a stock map sensor it isn't going to see 14 psi of boost. sounds to me like you might have some tuning issues like stated above
Old Apr 7, 2008 | 05:55 PM
Default Re: (cjordan)
no i am not running a stock map sensor, when i look at the a/f ratio gauge when i am boosting it is running rich, so thats good.but i don't put it to 14 lbs anyways, just usually 4-6 lbs. for daily driving. on my boost/vacuum gauge. when i idle it shows 23-24hg is that okay? head suppose to be like 20-22hg. also the piggyback ecu is tuned for stock engines, the ecu came with the kit to also deal with the 4 additional injectors in back of the intake manifold. i am using a walbro 255lph it to run the gas.
Old Apr 8, 2008 | 06:19 AM
95jeremie's Avatar
pull that pos tuning crap and go chip your ecu
pick up some RC440cc injectors (only 4 of them )
running rich is not a good thing it can wash your rings and destroy your motor
you said that your not running the stock map however at 14psi your check light is on?
why is that?
you need to get it on a dyno to get a good tune on it.
i will stay with my original assumption with it being your head lifting
causing your HG not to seal properly while in boost thus causing a HG leak
do a compression test to check for this
regardless i recommend you get a new HG and ARP head studs asap
at 115k it's about that time...
mechanic's now very little about tuning go to a speed shop and ask there opinion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civic ex &raquo;</TD></TR><TR><TD CLASS="quote">when i idle it shows 23-24hg is that okay? head suppose to be like 20-22hg. </TD></TR></TABLE>
by "it" shows... what is "it"?
i truly have no idea what your talking about
Old Apr 8, 2008 | 08:43 AM
what is a good a hg? mr.gasket,oem?
Old Apr 8, 2008 | 09:14 AM
95jeremie's Avatar
OEM only
don't use anything else
Old Apr 8, 2008 | 10:29 AM
Scheizty's Avatar
Default Re: (balljoint18)
If there is watercooling between the turbo and the engine, then it sounds like there is water leaking into the intake under boosting conditions.
Old Apr 8, 2008 | 12:45 PM
Default Re: (Scheizty)
i will check that tonight. is changing the head studs hard? from 1-10 what is the diffcultly level? when i had the the old turbo on it didn't smoke, only when i put on the new one. so my first reaction was the coolant hose to the turbo.... oh yeah when it got first dyno'd using the piggyback ecu, got pretty good #'s considering stock internals on a d series. to the wheels was 190 at 8lbs.
Old Apr 8, 2008 | 12:50 PM
95jeremie's Avatar
Default Re: white smoke problems.... (2000civic ex)
https://honda-tech.com/zerothread/2271816
totsie7944 is the creator of this post
look at his sig.
some nice parts for sale
RC440 saturated injectors currently have the same thing in my setup
AVC-R boost controller currently have the same thing in my setup
and a MSD 3-bar map sensor
just thought you might be interested
Old Apr 8, 2008 | 12:52 PM
95jeremie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civic ex &raquo;</TD></TR><TR><TD CLASS="quote">to the wheels was 190 at 8lbs.</TD></TR></TABLE>
ya I'm willing to bet it's your HG
when you smoke where is it coming from? hood/exhaust?
changing headstuds are not that bad
i would say a...7
Old Apr 8, 2008 | 01:31 PM
exhaust, not from the engine side,when i start up no smoke, when i drive there is some white smoke, not all the time though, sometimes, thanks for the parts, that would help. like when i was boosting 6 lbs yesterday, it was smoking for like 5 seconds then stopped. it isn't like dark white, it is like a light white smoke.thanks for the help
Old Apr 8, 2008 | 01:32 PM
what kind of car you have, and what turbo are you using?
Old Apr 8, 2008 | 04:31 PM
95jeremie's Avatar
95 ex
d16a1
not boosted yet
but will be
kit is...
t28 turbo (fast spool good for DD) and is water cooled to
greedy FMIC
2.5" cold and hot charge pipes
2.5" DP
log mani
type s BOV
rc 440 injectors
walboro fuel pump
avc-r boost controller
2.5" full exhaust with high flow cat (sounds kick *** )
arp head studs
fresh oem HG
crome tuned p28 ecu
motorola 2.5 bar map
looking for 230whp and 180-190trq
just looking to have some fun to and from work. not any tracks (drag) near me so will be doing the auto-x thing.
Old Apr 8, 2008 | 05:18 PM
2000d16y8
performer x kit from edelbrock
msd spark wires
1 step colder spark plugs
2 3/4 straight down pipe
tial bov
8 fuel injectors
manual boost controller
walboro pump
got alot other stuff on it too. too lazy too name it though
Old Apr 9, 2008 | 02:18 AM
i checked the intake, no coolant, i took off the valve cover and there was no coolant up there, but i noticed now that there isn't that much smoke any more, it is kinda like slowly going away....not sure though.
Old Apr 10, 2008 | 06:22 AM
95jeremie's Avatar
it could be the turbo settling in i guess
regardless head studs and HG along with a good tune will go a long way
SOHC heads have history of lifting
so look at it as preventative maintenance
glad to hear
Cyber ITR
Jan 29, 2007 09:58 PM
whatala
Sep 26, 2006 12:10 PM
DANG YO
Nov 21, 2003 11:33 AM
extrmeboost
Jun 13, 2003 08:00 AM
Malice
Mar 5, 2002 04:07 PM
