Twin scroll wastegate problem?
Old Apr 1, 2008 | 02:35 PM
PARADOX_sf's Avatar
Default Twin scroll wastegate problem?
How many wastegates i must use? I saw some pics of turbo era's F1 engines that are using 1 WG. Can single wastegate seal enough good or i must use two separate wastegates?
Old Apr 1, 2008 | 02:59 PM
blinx9900's Avatar
Default Re: Twin scroll wastegate problem? (PARADOX_sf)
how much power are you planning on making? do you have a divided housing manifold? do you have a divided turbine housing on your turbo?
Old Apr 1, 2008 | 11:27 PM
PARADOX_sf's Avatar
Default Re: Twin scroll wastegate problem? (blinx9900)
Yes, they are divided. I am planning around 500-600hp from b16a2.
Old Apr 1, 2008 | 11:59 PM
HiProfile's Avatar
One big WG would work, unless you're planning on running low boost for traction as well as high boost for power. A single large WG doesn't always react as fast, which is why people put 2 wg's on divided setups. You can do a single and keep everything the dual-scroll gives you, but the tube from the runners to the WG have to be divided right up to the WG valve. Once the gas hits the low pressure area after the valve, it won't revert back into the other side since the other runner is at a much higher pressure than the dump tube.
So if you have space/money restrictions, I'd go with a fully-divided single WG, otherwise a dual wastegate setup would be best for controlling boost. You could also do it like OEM's do, run a single WG off one vane. Thats only done because its cheap though.
Old Apr 2, 2008 | 12:49 AM
PARADOX_sf's Avatar
Default Re: Twin scroll wastegate problem? (HiProfile)
Thanks man!!!
98tegLSvtec
Jan 8, 2011 02:14 PM
Aero91
May 11, 2009 01:43 AM
Running925
Apr 25, 2009 07:48 AM
EJ1 wilcox
Jul 1, 2005 07:57 AM
16vt
May 29, 2005 10:55 AM
