Car hitting fuel cut when in boost...help
Old Apr 2, 2008 | 04:08 AM
boostedb18kid's Avatar
Default Car hitting fuel cut when in boost...help
just recently, my car hasnt been running the same. i got my s300 tuned back in december when it was 40 degrees out and now that spring is here, im wondering if the winter tune isnt accepting the warm weather very much. it seems like the car is running lean. even when fully warmed up, it will hit fuel cut at 5-6 psi @ 4.5-5k. then sometimes it will hit fuel cut at 2500 rpm in 2nd gear going 15 mph.
i checked all my vaccuum lines and they are all snug. am i correct in thinking that the car needs to be re-tuned? do u think the place should give me a free re-tune or should i have to pay for it again?
Old Apr 2, 2008 | 05:21 AM
blaze the chemi's Avatar
Default Re: Car hitting fuel cut when in boost...help (boostedb18kid)
How full is your gas tank?
Old Apr 2, 2008 | 05:32 AM
peakaboost's Avatar
Default Re: Car hitting fuel cut when in boost...help (blaze the chemi)
turbo cars need to be tuned atleast every six months (id say once spring/summer,again in fall/winter). You cant tune in cold *** winter weather and expect it to run like a champ in hot *** summer weather.
Old Apr 2, 2008 | 06:09 AM
1fastlude1's Avatar
Default Re: Car hitting fuel cut when in boost...help (peakaboost)
sounds like your hitting your boost cut if its hitting when you boost, did you change anything on the s300.
Old Apr 2, 2008 | 06:04 PM
98jdmcivic's Avatar
Default Re: Car hitting fuel cut when in boost...help (1fastlude1)
I had a similar problem, mine issue was fuel system was gunked up
Old Apr 6, 2008 | 11:30 AM
Default Re: Car hitting fuel cut when in boost...help (98jdmcivic)
i changed the fuel filter and it seems to still cut....
my s300 is set up to hit cut at 11 psi....tuned for 9.5. i mean i have aem fuel pressure regulator, walbro 255lph, and 525cc precisions, but with stock rail, which shouldnt be a problem.
i think my wastegate might be bad
vietdragontekx
Feb 4, 2006 12:14 AM
angela_itr
Apr 11, 2005 09:48 AM
blackeg
Jun 17, 2004 06:43 AM
Boostin95Teg
Nov 24, 2003 03:15 PM
Elite Hatch
Sep 25, 2002 10:10 AM
