lifespan of a F/I engine
Old Apr 5, 2008 | 04:53 PM
Dave_yd's Avatar
Default lifespan of a F/I engine
hi,
im in the process of building a b16 turbo engine, just wondering what the average lifespan of an engine is running approx. 15 psi on t3/t4
basic spec:
81.5 dart sleeved
je pistons
eagle rods
acl bearings
ARP studs
b16b cylinder head cams inlet
so how many miles of quite harsh driving befor it will develop issues- start smoking etc...and bearing in mind it is mapped well.
Dave
Old Apr 5, 2008 | 06:36 PM
H22Luda720's Avatar
Default Re: lifespan of a F/I engine (Dave_yd)
Give this a read, Its based for an H22 but i would say 90% applies to your b16 as well.
https://honda-tech.com/zerothread?id=783372
My .02c Tune it Properly!!!
Old Apr 5, 2008 | 06:49 PM
98vtec's Avatar
moderator emeritus
Default Re: lifespan of a F/I engine (H22Luda720)
11,683.45 miles.
too many variables.
piston to wall
ring gap
main and rod bearing clearance
proper assembly procedure
proper tuning
maintenance
Old Apr 5, 2008 | 09:12 PM
22psicrx's Avatar
Default Re: lifespan of a F/I engine (98vtec)
14550 miles b16 1.5 months. Just did a compression test. 175,175,175,175 on 9.0 comp.Just pulled it off the dyno again. 307 AND 280 TORQUE AT 27 PSI.
Old Apr 6, 2008 | 12:13 AM
tokesGTR's Avatar
Default Re: lifespan of a F/I engine (22psicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 22psicrx &raquo;</TD></TR><TR><TD CLASS="quote">14550 miles b16 1.5 months. Just did a compression test. 175,175,175,175 on 9.0 comp.Just pulled it off the dyno again. 307 AND 280 TORQUE AT 27 PSI. </TD></TR></TABLE>
That's a ton of boost for not much power. You sure it's not a D16A1?
Old Apr 6, 2008 | 08:51 AM
tannerLSt's Avatar
ME LOVE U LONG TIME
Default Re: lifespan of a F/I engine (tokesGTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokesGTR &raquo;</TD></TR><TR><TD CLASS="quote">
That's a ton of boost for not much power. You sure it's not a D16A1? </TD></TR></TABLE>
**** that still sounds low for 17psi .....
and 14k miles in 1.5 months... thats a LOT of miles
Old Apr 6, 2008 | 09:14 AM
JoePSI's Avatar
Default Re: lifespan of a F/I engine (tannerLSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt &raquo;</TD></TR><TR><TD CLASS="quote">
and 14k miles in 1.5 months... thats a LOT of miles</TD></TR></TABLE>
agreed, I'm averaging about 1500 miles a month, driving to work and school.. and I thought that was alot.
Old Apr 6, 2008 | 09:23 AM
stockb18c's Avatar
i think that was sarcazum..but ya
b16a with b16a2 pistons and rods
acl bearings arphead studs
stock head milled like .005
t3/to4b with agressive wheel and bigger compressor houseing on 9 psi
been runnin on 8 months knock on wood
love every minute of it. pulls hard gotta love the b16s
Old Apr 6, 2008 | 05:26 PM
JoePSI's Avatar
Default Re: (stockb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockb18c &raquo;</TD></TR><TR><TD CLASS="quote">i think that was sarcazum..but ya
love every minute of it. pulls hard gotta love the b16s</TD></TR></TABLE>
Why is your avatar a GSR? (old engine to match ur name?)
Old Apr 6, 2008 | 07:12 PM
trini-gsr's Avatar
i'm running:
b18c1
je pistons 9.5:1
eagle rods
stock sleeves and head
arp head studs
garrett t3/t4
makes 285whp/210wtq at 10.5 psi, no boost controller. it's my daily driver, has been for 1.5 years...there's probably 45-50k on the motor since the rebuild, 30k of those miles i put on myself. the seals are going on the turbo now...but the motor is still running strong.
Old Apr 6, 2008 | 07:59 PM
22psicrx's Avatar
Default Re: lifespan of a F/I engine (trini-gsr)
The turbo is an 18g that I had four 7 years. I purchased it in 2001 as a Greddy kit. It has made over 360 at 20 psi. THe turbo is bad and blows oil. The point of the dyno run. A t67 will be installed on monday.
Old Apr 6, 2008 | 08:10 PM
22psicrx's Avatar
I drive about 350 -450 miles a week. I have a diesel dually but diesel is to much money. $150 to fill the dually and 40 to fill the Honda a week.
celliott92
Oct 22, 2014 04:45 AM
22psicrx
Mar 1, 2007 06:54 PM
kinkyintegra
Jan 12, 2007 04:40 AM
89B16Civic
44
Jan 28, 2006 09:50 PM
SPOOLINmatt
Jul 14, 2005 06:07 PM
