NEED BOOST HELP !! ANY REPLIES !!!
Old Apr 4, 2008 | 08:55 AM
burks's Avatar
Default NEED BOOST HELP !! ANY REPLIES !!!
THis is pretty simple..I have a 2nd gen teg ls turbo pretty standard t3/t4 setup..I have 450cc injectors and was tuning with chrome..I got a Map from Xecron that was supposed to be good..BUT..this is my problem..IF i drive the car normal(meaning NOt allowing the car to enter boost, it Drives perfect..), but as soon as i try to step on the pedal and enter boost..it's just breaks up and doesn't let boost..i personally think..i need to get it tuned. BUT one of my good friends is set on it being something mechanical..i've looked over the setup with 3 or more different people and everyone says the setup looks fine..I mean theres not that much to a turbo kit.. FOOTNOTE: ive went through about 4 pairs of spark plugs moving the car a few times b/c their dripping black when i pull them out after starting the car..ANY ADVICE ?? or should i go with my gut and spend the money to get it street tuned ?
Old Apr 4, 2008 | 08:56 AM
slodel's Avatar
Default Re: NEED BOOST HELP !! ANY REPLIES !!! (burks)
tune it already
on a dyno
Old Apr 4, 2008 | 11:18 AM
95dc2teg's Avatar
Default Re: NEED BOOST HELP !! ANY REPLIES !!! (slodel)
your not even really supposed to be boosting with basemap. a basemap is just so your car can run the injectors so that you can drive it to a tuner to get tuned...
Old Apr 4, 2008 | 11:35 AM
havok hybrid's Avatar
Default Re: NEED BOOST HELP !! ANY REPLIES !!! (95dc2teg)
my 1st guess is your Chrome basemap is still set for Stock 240cc injectors.. and you have 450cc in there..
put some stock injectors in there.. DONT BOOST.. and drive to a dyno ..
Bring you 450cc injectors and install them at the dyno....
Old Apr 4, 2008 | 01:09 PM
95dc2teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by havok hybrid &raquo;</TD></TR><TR><TD CLASS="quote">my 1st guess is your Chrome basemap is still set for Stock 240cc injectors.. and you have 450cc in there..
he has his 450cc injectors installed and the car runs find under normal driving conditions, which means his basemap is for his 450 injectors already. hes have trouble boosting because your not supposed to be boosting with a basemap and it probably has a boost cut set at 1 or 2lbs.
Old Apr 4, 2008 | 01:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg &raquo;</TD></TR><TR><TD CLASS="quote">
he has his 450cc injectors installed and the car runs find under normal driving conditions, which means his basemap is for his 450 injectors already. hes have trouble boosting because your not supposed to be boosting with a basemap and it probably has a boost cut set at 1 or 2lbs.</TD></TR></TABLE>
I overlooked some of the posts b4 i posted... ..
I agree...
Old Apr 4, 2008 | 03:51 PM
SpoolnG2's Avatar
Default Re: NEED BOOST HELP !! ANY REPLIES !!! (havok hybrid)
Tune Tune Tune....otherwise your just gonna blow your **** up.
DRIVENRacing
Honda Civic (2001 - 2005)
10
Feb 11, 2010 08:11 AM
thermostate82
Jan 1, 2009 10:46 PM
burks
Apr 4, 2008 12:39 PM
drintegra
May 22, 2006 05:26 AM
desert eagle
Aug 4, 2004 06:34 PM
