help!!!!!! with turbo-smart dual stage boost controller
Old Apr 4, 2008 | 07:12 PM
boosted_ejcivic's Avatar
Default help!!!!!! with turbo-smart dual stage boost controller
i am just really confuse on how to wire up the switch that changes over from low to high boost
on boost controller you have 2 wires a brown (ground) and a blue (positive) wire
now i have the kill switch that changes the boost from low-high
how do i wire up the kill-switch to the boost controller
i have searched and on there intructions they dont say much
thanks for the help
Old Apr 5, 2008 | 03:21 AM
Redline130's Avatar
Default Re: help!!!!!! with turbo-smart dual stage boost controller (boosted_ejcivic)
The blue wire is run to the switch and then from the switch to a 12 volt fused power source. I would say a switched power source would be best (activated with the key in the "on" position in the ignition switch). The brown wire goes to a chassis ground.
Old Apr 6, 2008 | 09:10 AM
Default Re: help!!!!!! with turbo-smart dual stage boost controller (Redline130)
so do i run the blue wire to the high boost switch?
then what about the low boost all it gets its power?
Old Apr 6, 2008 | 11:10 AM
Redline130's Avatar
By activating the switch (power on) you switch the boost controller to the high boost setting. With the power off, the boost controller remains at the low boost setting.
Old Apr 7, 2008 | 04:07 AM
so pretty much the low boost setting dosnt get any power...........
the only thing getting power is the blue wire that runs to the high boost switch
Old Apr 7, 2008 | 09:48 AM
Redline130's Avatar
Default Re: (boosted_ejcivic)
Yes
Old Apr 7, 2008 | 03:13 PM
ok thanks
jv88_dc2
Jun 12, 2012 03:49 AM
bb6kid22
Engine Management and Tuning
Nov 1, 2010 05:03 PM
85
Sep 1, 2010 12:59 PM
blwn95civic
Apr 5, 2007 09:41 AM
boostincoupe
Jan 7, 2005 01:17 PM
