boost keeps spiking?? what could it be?
Old Apr 6, 2008 | 07:07 AM
Eklsv-t's Avatar
Default boost keeps spiking?? what could it be?
I have ls vtec setup with drag kit and upgraded precision sc34 turbo. I was at CMI and notice my boost to spike to 15psi so I let go pedal at track. Btw I have Turbonetics delta wastegate. Could be the wastegate causing the problem? What do you guys recommend? I am also running rich when I spike to 15psi
Old Apr 6, 2008 | 09:27 AM
stockb18c's Avatar
could be the wastegate could be vaccumm lines are you runnin a boost controller could be that too with spring are you runnin in the wastegate
Old Apr 6, 2008 | 11:39 AM
Eklsv-t's Avatar
Default Re: (stockb18c)
im not running boost controller, vacuum lines are all hooked up no vacuum leak it is set at 20 at idle. What do you guys think, SHould i get tial wastegate or get boost controller
Old Apr 6, 2008 | 01:08 PM
b16bri's Avatar
Default Re: (Eklsv-t)
If you plan on raising your boost levels than yes get a boost controller, as far as your boost creep, Id'e say it probualy due to your wastegate. I've never used the delta gate but i've herd nothing but bad about them. So bad wastegate + poor waste gate location on the drag manifolds could equal boost creep. Get a Tial and it will probually go away
Old Apr 6, 2008 | 02:07 PM
RedneckRicer's Avatar
Notorious problem for the Drag Manifold. swap it out for a better manifold i believe blox makes one with the center mount wastegate. and im sure the delta gate is contributing to your problem as well havent really seen anyone run a delta gate since back in 2001 ish
Old Apr 6, 2008 | 03:01 PM
b16bri's Avatar
Default Re: (RedneckRicer)
Yeah blox dose have a mani were the wastegate is in the collector insted of in the runner. weather you switch mani or not change the wastegate
Old Apr 6, 2008 | 07:19 PM
stockb18c's Avatar
im using a drag mani and have no problem actually im runnin a psi lower then what the spring is
Old Apr 6, 2008 | 07:27 PM
b16bri's Avatar
Well not everyone who runs a drag mani has problems. Are you useing a delta gate or a tial. At low boost with a tial and that mani in theory you should be fine. But there are plenty of storys with people running thoes manifolds and having issues. In Eklsv-t case he's running 15 psi and deff should get a tial and it will probually clear the problem but someone mentioned blox and all i was getting at was if you like the drag mani and everything fits fine blox makes almost the same kind just with a better waste gate location.
Old Apr 6, 2008 | 08:07 PM
Redline130's Avatar
Default Re: boost keeps spiking?? what could it be? (Eklsv-t)
I had a Drag manifold and a Tial 35mm wastegate with a SC50, boost creeped from 15psi to 17psi consistently.
With an InlinePro manifold, Tial 44mm gate, and a GT40R, no boost creep problems at all.
What kind of boost controller are you using? With the drag manifold I used a Turbosmart single stage controller, with the other set-up I used a Turbosmart E-Boost 2 electronic boost controller.
Old Apr 6, 2008 | 08:08 PM
Eklsv-t's Avatar
Default Re: (b16bri)
ill probably just get a tial wastegate. I used to have tial on my old gsr setup and no boost creep.
turbo_d
Jun 5, 2022 06:46 PM
CX-T
Jun 19, 2008 09:22 AM
Racer X
Mar 27, 2003 01:07 PM
