manual or electric
Old Apr 4, 2008 | 12:04 PM
IAluder95's Avatar
Default manual or electric
i was curious to what you use to set your boost level with? i was wondering if it was worth it to get a EBC. i heard good things and bad things about them.
if you use an EBC what type are you running? was it worth the purchase?
i havent seen any EBC made especially for hondas.
Old Apr 4, 2008 | 02:04 PM
IAluder95's Avatar
bump
Old Apr 4, 2008 | 03:48 PM
SpoolnG2's Avatar
Default Re: (IAluder95)
Tell us a little bit about your setup, goals, what ems your gonna be running, etc.
A nice setup is to use aem, hondata, etc and use the boost control with that and a boost solenoid. That way everything is controlled and tuned and you can use boost by gear once you start making a lot of power.
Old Apr 4, 2008 | 04:23 PM
IAluder95's Avatar
H23a1 H22a head. (h23vtec)
2.4L sleeved by darton
STR cam gears
8.5:1 weisco pistons
mahley turbo tuff rods
cometic head gasket
super tech flat valves
crower stage 2 turbo cams, retainers, spring ect
blacktrax stage four intake manifold
Hondata S300 boost with P28
Oaks Racing old turbo set up.
Cast T3 manifold with adapter pipe to T4 flange- jet coated
TEC T4OE Turbo with .81 AR housing - jet coated
Turbonetics Delta gate mark II wastegate with extention tube and dump tube
HKS Super sequencial BOV
Intercooler Spearco brand 3 1/2" thick
manual boost controller
3 piece boost pipe 2 1/2"
92# Venom injectors
Old Apr 4, 2008 | 07:25 PM
Rbehne2's Avatar
It all depends on the user. alot of ppl use manual with the hondata systems. I know alot of ppl who use the GM boost solenoid with aem, but that might be a little extensive for your goals.
Old Apr 4, 2008 | 09:15 PM
Dartanian's Avatar
Default Re: manual or electric (IAluder95)
Purchase a solenoid and set up PWM boost control through the S300.
Old Apr 5, 2008 | 07:20 AM
IAluder95's Avatar
which solenoid are usually the best for the buck?
Old Apr 5, 2008 | 09:17 AM
SpoolnG2's Avatar
I would reccomend going with the hondata boost solenoid since you are already using the s300. I def would not go with a GM boost solenoid due to the fact they are "normally open" and if your solenoid fails you overboost. Where as the hondata one is "normally closed" and if something fails you just go right to spring pressure in the wastegate.
Old Apr 5, 2008 | 09:23 AM
KENetics1's Avatar
i hear good things about the ectune pwm solenoid also.
Old Apr 5, 2008 | 10:48 AM
IAluder95's Avatar
does the hondata come with the solenoid? i havent purchased the hondata yet.
Old Apr 5, 2008 | 10:51 AM
KENetics1's Avatar
s300 does not come w/ boost solenoid. you also have to have the ecu chipped to run pwm boost control.
Old Apr 5, 2008 | 02:09 PM
IAluder95's Avatar
i got a prehondata socketed ecu.
Old Apr 5, 2008 | 02:52 PM
rudebwoy's Avatar
I used to run a dual stage txsbc I loved it .and then someone gage me a greddy profec s ebc, and I love it even more, I can adjust how fast I uild boost, and switch from high to low boost from a button on my steering wheel. I love it.
but something I spiked don't know whats causing that, but hope I figure it out soon. ebc is great!
Old Apr 5, 2008 | 07:37 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IAluder95 &raquo;</TD></TR><TR><TD CLASS="quote">i got a prehondata socketed ecu. </TD></TR></TABLE>
You'll still have to add the components necessary to complete the EGR circuitry in the ECU and allow PWM boost control. Xenocron can hook you up with what you need or you can send your ECU in and have the components installed for you.
Old Apr 6, 2008 | 09:43 AM
IAluder95's Avatar
alrighty
Chrisatrturbo
Nov 6, 2014 09:44 AM
pinoyk20
Nov 2, 2006 04:35 AM
SleepersOwn
Jan 1, 2006 05:32 PM
1fastgsrturbo
Sep 29, 2003 07:38 PM
