what turbo to get?
Old Apr 4, 2008 | 07:12 AM
laziebun's Avatar
Default what turbo to get?
Im looking to get a new turbo soon and need a few advice. Im looking to make around 350-500whp. What turbo would H-T?. Setup right now is a GSR stock head and fully built bottom end.
Old Apr 4, 2008 | 08:50 AM
Boosted_B_Series's Avatar
I got a garrett 60-1 for the same power goals you are wanting. I love it. its .63 on the exhaust side and .70 on the blower side.
Way to rep KY man. Ever attend any meets?
edit: I have a built gsr bottom end, stock head, stock sleeves.
Old Apr 4, 2008 | 09:12 AM
Schister66's Avatar
Man U FTW
One thing that would help narrow your selection would be a few more specific goals like when you'd like to see full boost, an approximate budget and use for the car. Also, listing your setup would give us a better idea as well.
I'm in the same boat as you basically and i opted for the Borg Warner S256. It's comparable to the GT3076r but without the ball bearing cartridge. I like that fact because on the off-chance that i have problems, the center section is rebuildable. Also, you dont have the hassle or expense of water lines. If you want more info, PM Turbodano, TheShodan or TTT. They can give more of the specifics of the turbo. I know it will easily make your goal of 500whp...ive seen it make nearly 575whp @ ~32psi (IIRC).
Old Apr 4, 2008 | 09:30 AM
laziebun's Avatar
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">One thing that would help narrow your selection would be a few more specific goals like when you'd like to see full boost, an approximate budget and use for the car. Also, listing your setup would give us a better idea as well. </TD></TR></TABLE>
here's my set up, and it's for a daily driver and my budget it around $700.00
99 Civic EX
97 GSR motor
Stock Head
Stock Intake Manifold
B18c1 block AEBS Sleeves 81mm
SRP 9:5:1
Inline Pro Rings
Golden Eagle Rods
All ACL Bearings
ARP Head Studs
780cc Precission Injectors w/ Honda resistor pack
Inline Pro turbo SS Manifold
Turbo Smart Waste Gate 38mm
excedy stage 2 clutch
excedy flywheel
thermal 3" catback
Hondata s300
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted_B_Series &raquo;</TD></TR><TR><TD CLASS="quote">
No not really, im all the way up at Ft.Campbell KY
Old Apr 4, 2008 | 09:41 AM
LA_HONDAS's Avatar
Default Re: (laziebun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laziebun &raquo;</TD></TR><TR><TD CLASS="quote">
Golden Eagle Rods
golden eagle dont make rods
its eagle rods
Old Apr 4, 2008 | 03:57 PM
SpoolnG2's Avatar
Default Re: (LA_HONDAS)
BW S372
Old Apr 4, 2008 | 05:50 PM
Schister66's Avatar
Man U FTW
Default Re: (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">BW S372 </TD></TR></TABLE>
Too large for his power goals and out of his budget. All of the S200 and S300 series are above $1000. I would suggest PMing TheShodan and see what he has for that budget. Generally if you want a good turbo to make 500whp, you're going to need to shell out a few more bucks for a good turbo
Old Apr 5, 2008 | 09:20 AM
SpoolnG2's Avatar
Too large for his power goals and out of his budget. All of the S200 and S300 series are above $1000. I would suggest PMing TheShodan and see what he has for that budget. Generally if you want a good turbo to make 500whp, you're going to need to shell out a few more bucks for a good turbo</TD></TR></TABLE>
Just for the record, I was playing around...hence the . Just seems like everyday hundreds of people ask this same questions without researching on their own.
Old Apr 5, 2008 | 09:40 AM
RedneckRicer's Avatar
SC6152 is a nice turbo and resonably priced.`
Old Apr 5, 2008 | 10:08 AM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">Just for the record, I was playing around...hence the . Just seems like everyday hundreds of people ask this same questions without researching on their own. </TD></TR></TABLE>
Ahh...gotcha. I'm not always the most observant and sarcasm is a hard thing to convey online.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedneckRicer &raquo;</TD></TR><TR><TD CLASS="quote">SC6152 is a nice turbo and resonably priced.`</TD></TR></TABLE>
Thats not a bad choice, although there are better turbos out there IMO. The only problem is that his budget wont allow for an all around great turbo. Having something like the 60-1 will make your power goal, but at the expense of more lag time than necessary if you had gone with a better turbo...get my drift?
Old Apr 5, 2008 | 10:09 AM
TheShodan's Avatar
Moderator
99 Civic EX
97 GSR motor
Stock Head
SRP 9:5:1
Inline Pro Rings
Golden Eagle Rods
All ACL Bearings
ARP Head Studs
excedy flywheel
thermal 3" catback
Hondata s300
No not really, im all the way up at Ft.Campbell KY</TD></TR></TABLE>
With your budget of $700, your options are limited to the 60-1 w/ the stage III wheel , to get close to the 500whp mark. If you're leaning more towards the 350-450whp mark, the standard "trim" (57 & 60 "trims") can work well for those needs. The stage III 60-1 is about $715 dollars, but with the manifold that you have, and want to keep A/C (let us know otherwise), triming of the block to fit that large of a compressor housing can present its problems.
Old Apr 5, 2008 | 01:39 PM
nowtype's Avatar
60 Trim T3/T04e
T3 60-1
SC61
GT4088 Journal Bearing
Holset HX35
Holset HY35
Depends on where you want the power which I'd suggest fully.
EG_SINZ
Dec 15, 2010 08:35 PM
Eplusz
Mar 20, 2010 11:34 AM
sanegb16
Jan 12, 2009 07:59 AM
mastakmk
May 15, 2007 10:00 AM
pr0phet
Nov 23, 2005 04:53 AM
