question regarding pistons
Old Mar 5, 2002 | 05:49 AM
b18bturbo's Avatar
Default question regarding pistons
I was doing some calculations and some measurements last night. Are most valve releifs on aftermarket pistons sized at .508 inch depth. The way we clayed the motor i had in there currently it shows that i have approx .0180 inch of room available even though the piston is slighly above the GE block which is .0018 of inch.
So i figure i have plenty of room to run the oversized ferrea valves on a Wiseco piston from larry.
even on my older JE piston the valve relief was cut .508 is this std thing that all manufacture adhere to.
Old Mar 5, 2002 | 05:51 AM
MackSpeed-616's Avatar
Default Re: question regarding pistons (b18bturbo)
what exactly is the question? i didnt see a single question mark in your entire statement. however i say je 8.8 + eagle rod
Old Mar 5, 2002 | 05:54 AM
DSF's Avatar
DSF
Well, the literature that came with my Wiseco pistons I just received said they oversize the valve reliefs on all of their pistons to accomadate slightly oversized valve heads. Sorry no specs, but I thought I'd share.
(This JE piston/Eagle rod thing is getting VERY tiresome )
[Modified by DSF, 9:56 AM 3/5/2002]
Old Mar 5, 2002 | 06:00 AM
b18bturbo's Avatar
Default Re: question regarding pistons (TurboR616)
this eagle rod and je piston **** is getting out of hand.
Old Mar 5, 2002 | 06:39 AM
rtype11's Avatar
I am at a slight loss but want to help with your question, but first what measurement if .508" inch, no way that is the relief depth on any pistons I have seen, that is over one centimeter. thanks to explain, p.s. there is a piston to valve clearance that you should respect, I know you are trying to maximize the proximity of valve to piston - or max valve lift, but you can get more flow by maximizing the airflow at lower lift by getting a cam made that will maintain that.
Old Mar 5, 2002 | 07:20 AM
X2BOARD's Avatar
Default Re: question regarding pistons (rtype11)
Why don't you be really different and get Eagle pistons and JE rods ?
Old Mar 5, 2002 | 07:25 AM
Gmedalion's Avatar
Viren said it right:
Im getting tired of it as well, funny at first but no so funny afterwards.
[Modified by Gmedalion, 8:33 AM 3/5/2002]
Old Mar 5, 2002 | 07:27 AM
b18bturbo's Avatar
Default Re: question regarding pistons (Gmedalion)
Vire said it right:
damn straight this getting out hand. this stupid now...
Old Mar 5, 2002 | 07:47 AM
Arturbo's Avatar
Better than steak
25 Year Member
I agree. The Eagle rod je piston was funny at first but now everyone says it. I even took it out of my sig so lets get back to tech. I dont mind the joking around everyonce and a while, but dont kill the joke to death.
art
Old Mar 5, 2002 | 07:50 AM
rtype11's Avatar
can you answer my question re 0.508" relief depth?
pitbullGUY
Dec 7, 2012 05:53 AM
SOHC_MShue
Feb 14, 2006 05:51 PM
paulzy
Mar 24, 2005 06:51 PM
Hockey27925
Dec 22, 2004 08:11 PM
forcedaccord95
Feb 10, 2003 11:08 AM
