any body have a t3/t4 with an .82 a/r on the turbine?
Re: any body have a t3/t4 with an .82 a/r on the turbine? (internet ay)
dont do it!!
the lag is unbearable and the car falls completely on its face with anything below 5500. bleh.
it matters what size motor its going on if its a good price ill buy the t3/t4 with the .82 housing they have killer top end it don't mater when u start spooling u just need to stay in boost when u going Thu the gears
on the street 1st gear is **** anyhow on a turbo car making any power
Re: any body have a t3/t4 with an .82 a/r on the turbine? (DLB1994)
I think Internet ay has a CRVTEC (2.0L) with a redline of I cant remember what. I know a lot of H22 Luders that are running .63 exhaust A/R's and they usually hit 7-10 PSI by 3800-4000 RPM's (7400 redline)
Re: any body have a t3/t4 with an .82 a/r on the turbine? (BlueShadow)
i have a ls/vtec bored to 84 mm, which is somewhat close to a 2.0 with a redline of 8500.
I was running a NON Ball Bearing T3/T04E (.82 A/R Turbine Housing Stage III Turbine & .60 A/R Compressor Housing 57 Trim Compressor Wheel) with a stock SR20DET w/ 8.5:1 CR and I began boosting by 3200 rpms and had full boost by 4500 rpms. This is a 2.0L motor! It was Wicked on the top end. I personally like it on the street! It was very predictable when boost was going to come on only because you knew you were going to have some lag, where as the .63 A/R housing spooled up sooner and had power sooner, but it also didn't have as much of a "Punch" up top!
Re: any body have a t3/t4 with an .82 a/r on the turbine? (APEXSER)
hi this is internet ay, i will be running around 9.3 to 1 compression running somthing like 10 psi on the street and 20+ at the track if that helps
Re: any body have a t3/t4 with an .82 a/r on the turbine? (AGen2integra)
louis, will this turbo still be streetable with the .82 a/r, stage 3 wheel.60 trim, .60 a/r??
we used this turbo:
60-1 with a p trim T4!!! in a .82 a/r housing
the car fell out of boost between shifts and was absolutely the wrong turbo. I have felt the t3t4 .63 and if you have a street car that is a WHOLE LOT of turbo. i dont think you could possible need more of a turbo than that.
this was on a 1.9L gsr with 9.5:1 comp, race car.
Re: any body have a t3/t4 with an .82 a/r on the turbine? (FFgeoff)
we used this turbo:
I am now running an .82 A/R housing Stage V turbine & .60 A/R T04E compressor housing 60 trim compressor wheel on my car. I will have a bit more lag now than before, but it will support 500+ whp without any problems on my car. I have seen this turbo produce 497 whp with a stock cast iron SR20DET manifold! The boost levels were high (28-30 psi) but the manifold is also very ineffiecient as well. This turbo is being used on a Daily Driven 200SX SE-R. Ben B also layed lown 524 whp with this turbo and a log style manifold! I should have no problem making 500+ with my new equal length stainless steel manifold!
APEXSER, the turbo guru, how much lag is there between a .48a/r and a .63a/r? for my b18b1 RS (6800rpm redline). what would be the difference in spool up time? i hear the .48 will fall off in high rpm's but i dont have a high redline.
Re: any body have a t3/t4 with an .82 a/r on the turbine? (cyan1de)
elpiar
09-06-2005 08:01 AM
