VAFC hack and 2nd 3 bar map sensor
Old Mar 9, 2002 | 06:56 AM
PrecisionPerformanceParts's Avatar
Default VAFC hack and 2nd 3 bar map sensor
Is anyone running this setup effectively now?
Any updates?
Old Mar 9, 2002 | 07:07 PM
zojirushi's Avatar
Default Re: VAFC hack and 2nd 3 bar map sensor (fatkid)
u can do that unless u modify honda's ecu
Old Mar 11, 2002 | 02:39 AM
DSF's Avatar
DSF
Default Re: VAFC hack and 2nd 3 bar map sensor (zojirushi)
huh?
Old Mar 11, 2002 | 07:24 AM
Default Re: VAFC hack and 2nd 3 bar map sensor (DSF)
I am asking if someone has got the vafc hack to work by using a second map sensor wired to the vafc only and using a missing link on the stock map sensor.
Old Mar 11, 2002 | 07:31 AM
DSF's Avatar
DSF
https://honda-tech.com/zerothread?id=137901
https://honda-tech.com/zerothread?id=140472
Between these two posts, you shouldn't have any questions
Old Mar 11, 2002 | 09:47 AM
Thanks for the help, but I have read all of those posts, I know the one talks about swapping in a 3 bar map sensor for the stock map sensor, but I want to know if anyone has been running a missing link on the stock map sensor and has wired in a 3 bar map sensor for just the VAFC to make air and fuel correction. So, they would be running 2 map sensors.
Old Mar 11, 2002 | 10:01 AM
DSF's Avatar
DSF
Again, huh? Why would you run two MAPs? If your talking about running a 3bar to the TPS circuit of the AFC, the answer is in the posts. If your talking about running a 3bar to the MAP circuit of the AFC, and a limited (missing link) MAP to the ecu, that's obsurd. If you want to know why, then re-read the provided posts.
Old Mar 11, 2002 | 11:08 AM
https://honda-tech.com/zerothread?id=75967
This is what I am talking about.
Old Mar 12, 2002 | 02:53 AM
DSF's Avatar
DSF
Yes. And that topic, the original AFC hack by dbman96, was discussed in the thread I already posted. Read, reread, print it out, roll it up and smoke it. Trust me, the truth is out there...
igo4bmx
Apr 13, 2004 04:13 PM
dominate9
Nov 15, 2003 01:01 PM
forced-d16
Sep 22, 2002 11:46 PM
98civicEX
Sep 19, 2002 07:37 PM
Turbo EG6
Aug 19, 2001 05:04 PM
