B Series Turbos... Need Help Quick...
SI and GSR motors are both B series motors. So the manifold will fit, the turbo will fit. The intake and intercooler piping will be different for each application.
The turbo itself that comes with each turbo kit is usually speced against the flow rate of the motor. I.e., the DRAG B16 kit uses a t3/t04b whereas the B18C1 uses a t3/t04e.
but as dbman96 said, they will fit with exception of the upper intercooler pipe (LS and B16 match up, though)
If you are referring to the greddy kit, the blue box is different for almost every application.
Dustin
Dustin
So does the T304e spool slower than the b. And how do you know which one you have. What are the differentiating marks on the two. Mine is a .50 intake, the turbo is bolted to the mani and Im too lazy to remove it, but does that number give a hint....??
