Quick Question for Hondata users
Old Mar 5, 2002 | 03:09 AM
therealnapster's Avatar
New User
Default Quick Question for Hondata users
I ordered a hondata stage 3b yesterday. I'm running the GReddy kit on a single cam vtec setup. How good did your cars run with just the base map, I know its supposed to be safe but any hp/tq gains w/just the base map? Also anyone using the launch control or full throttle shifting...any quarter mile time shaved off by this or is it more for consistancy? Cant wait for my ish to get here, any info welcome, good or bad, thanks.
.ad.
ps- Any one in the Chicago area w/editor and burner?
[Modified by sohckid, 12:16 PM 3/5/2002]
Old Mar 5, 2002 | 03:17 AM
TurbodCX's Avatar
Default Re: Quick Question for Hondata users (sohckid)
i just had my car dynoed and i put down 229whp and 190ft. lbs, of torque!!! out of a single cam with about 12plds of boost. it could have been more but i had 440cc injectors and at 50psi of static fuel pressure my injector duty cycle was at 100% at 7500 rpm. i would post the sheet but i cant get the pic thing to work.
Old Mar 5, 2002 | 04:45 AM
philo's Avatar
My original JRSC setup did not work too well with the base maps, but most of the probs I had should not be an issue with a turbo system. It should work pretty well.
But if you are getting a Hondata why not just have one of the turbo maps that they have already tuned put on the chip.
Old Mar 5, 2002 | 08:28 AM
TurboTegB18c's Avatar
My base map for a sohc turbo sucked. It might depend on who/where you get it from though. I have the drag kit too. I would advise you to make sure you get it tuned before running it hard.
Old Mar 5, 2002 | 08:47 AM
TurbodCX's Avatar
yeah sorry man i didnt really answer your question last time....
my base map really sucked also. it was really lean, the plugs stayed consitanly white. i had an a/f of about 15.5-16.2 on the wide band on the first pull of the dyno.
Old Mar 5, 2002 | 09:13 AM
TurboSedan's Avatar
New User
Default Re: Quick Question for Hondata users (TurbodCX)
Whoa damn, that is pretty bad even for a base map. Also, about the guy with 229hp at 12Psi. You have 8:1 pistons? I think that is robbing some power right there. 9:1 would be much more correct for your application, IMHO.
Old Mar 5, 2002 | 10:20 AM
TurbodCX's Avatar
Default Re: Quick Question for Hondata users (97CivicFerio)
yeah i am using 8:1 but with this setup i can safely put 15-20 psi on my motor with no probs, (less likely to detonate) and make mad horesepower.... i used this setup for personal preferance.
thanks for your opinion though..
Old Mar 5, 2002 | 10:47 AM
TurboSedan's Avatar
New User
It's all good, I was not ripping you. I guess I just wondered if 12Psi is all you were going to run with that CR. Now that you say you'll go much higher I can see why the real low CR.
Old Mar 5, 2002 | 10:48 AM
sgT's Avatar
sgT
You have to understand that the base maps arent meant to be raced on.
They are meant to get your car to the tuner.
Unless someone is giving you a previously tuned map, thats what its meant for.
Old Mar 5, 2002 | 05:07 PM
New User
Default Re: Quick Question for Hondata users (sgT)
I understand that the base maps are only meant to be used temparily untill you can get on a dyno, but the closest hondata tuner is a 5 hour drive away, I hope I have better luck with my base map, cause its a long haul from chicago to detroit.
[Modified by sohckid, 2:10 AM 3/6/2002]
Old Mar 5, 2002 | 06:30 PM
HXMan's Avatar
You going to Payn Tech also? I got an even longer drive then you!
Old Mar 5, 2002 | 11:52 PM
New User
Default Re: Quick Question for Hondata users (HXMan)
Yeah I got in on the one at groupbuycenter.com. I think I'm heading up there the week of the 17th, if I can get it installed and put my car back together. This all should be worth it in the end though. I think the base map I'm getting is from a d15 with a hks turbo...I have a d16 and GReddy turbo, its a diff engine and turbo, I'm screwed.
Old Mar 6, 2002 | 01:28 AM
SIK IN DA HED's Avatar
New User
im probabyl going to have the same problem you guys are having with the base maps once i get it installed.
Old Mar 6, 2002 | 01:43 PM
Xerxes's Avatar
New User
Default Re: Quick Question for Hondata users (dlplayboy)
I got a decent base map from Payn technologies. It idled fine and i was able to run 7psi of boost with no problems for a month before i hit the dyno. At the dyno i got 203whp with the base map and 7psi of boost.
It really all depends on who's base map you get and what car it was made for. When i doubt, turn up your idle fuel pressure to make sure that you'll have enough fuel under boost.
-Xerxes
Old Mar 6, 2002 | 01:52 PM
dustin's Avatar
I think the deal is that the maps are necessarily configured for your fuel system.
Old Mar 7, 2002 | 04:40 PM
New User
hey turbodCX, what is the difference between the JDM sohc and the us d16z6? Just curious.
.ad.
Old Mar 7, 2002 | 09:56 PM
New User
is there not a turbo map that was made for a stock LS turbo setup using a DRAG3 kit? they should have one.
Old Mar 8, 2002 | 05:15 AM
turbopanda's Avatar
i'm running 8.2:1 C/R on my D16Y8, its low yeah, but its great for daily driven high boost, and the car is still reasonably drivable when driving without boost, its really not as low as you think it is
Old Mar 8, 2002 | 07:49 AM
HXMan's Avatar
Default Re: Quick Question for Hondata users (nathan's boosted civic)
18psi!
Old Mar 8, 2002 | 11:07 AM
turbopanda's Avatar
8psi, badly tuned.
Old Mar 8, 2002 | 12:06 PM
FukieneseDragger's Avatar
how much are you guys paying for tuning?
hybridmiklo
Jan 10, 2013 11:52 AM
RudyCholo
Dec 5, 2006 07:30 PM
ITR9788
Jun 9, 2004 02:14 PM
superfuji57
Apr 8, 2004 09:17 PM
jamal-188
May 5, 2002 08:11 PM
