water temp sender vs. sensor
Old Mar 5, 2002 | 11:29 AM
bigTom's Avatar
Default water temp sender vs. sensor
which one is used for what... i was looking at my head and those 2 are there... which one does the water temp guage read off of?
Old Mar 5, 2002 | 11:30 AM
b18bturbo's Avatar
Default Re: water temp sender vs. sensor (Tom)
it reads off the one from the head next to VTEC solonoid is what i thought. But i know there another one in there to but i never paid much attention to it. I think thats for the fan temp control
Old Mar 5, 2002 | 11:37 AM
LsTurbo91's Avatar
the one with a single connector is for the water temp gauge in the gauge cluster. The other with the 2 wire green connector is the sensor that the ECU gets the input from.
Old Mar 5, 2002 | 11:41 AM
VaporTrail's Avatar
New User
Default Re: water temp sender vs. sensor (LsTurbo91)
^correct^ The ECU also determines from this sensor when to turn on the cooling fans.
Old Mar 5, 2002 | 03:53 PM
Xerxes's Avatar
New User
Default Re: water temp sender vs. sensor (VaporTrail)
On my car and i thought on most b-series hondas, the cooling fans are controlled by the thermoswitch, which is just a mechanical device that shorts its terminals together when the temperature goes above a certain point.
I thought the ECU only used the temperature sensor for stuff like cold idle control, cold enrichment, and cold start vtec control?
-Xerxes
Old Mar 5, 2002 | 04:22 PM
LsTurbo91's Avatar
Default Re: water temp sender vs. sensor (Xerxes)
-Xerxes
Actually there's 3, 2 in the head and one in the block near the oil pressure switch is the fan switch you are talking about. As for the idle control thats a different one and that is controlled by the IACV on the intake manifold.
Old Mar 5, 2002 | 04:26 PM
dustin's Avatar
I think that's the oil temp sender.... I don't think newer B series blocks have them(94+).
Old Mar 5, 2002 | 04:29 PM
LsTurbo91's Avatar
Default Re: water temp sender vs. sensor (dustin)
I think your right, I remember it was blocked off when I swapped the 94 LS in, I needed like a 27mm or close to that to get it out and screw in the sensor.
Old Mar 5, 2002 | 04:35 PM
dustin's Avatar
We just didn't hook it up on my friend's 97 LS -> 91 chassis swap....
But his radiator fans come on randomly when the car is turned off now
Old Mar 5, 2002 | 04:36 PM
bigTom's Avatar
good job
note to self; dustin is a wiring king! jk
Old Mar 5, 2002 | 04:48 PM
LsTurbo91's Avatar
hehe, that sounds about right, because I know the oil temp switch works when the car is off and if per the manual if the oil temp is a certan degree it will turn the condenser fan on, or the main fan.
BlackShingo
May 20, 2010 07:36 AM
SurferDude905
Apr 17, 2009 10:07 AM
crxsir07
Nov 12, 2006 04:05 PM
TypeR15
Feb 24, 2004 12:29 PM
2000_Civic_Si
Apr 3, 2002 07:45 AM
