what injectors should i get?
Old Mar 10, 2002 | 06:17 PM
93B17A's Avatar
Default what injectors should i get?
What do you guys recommend for injectors? i have a fully built car bottom/ top end, i know all my other fuel system (standalone, pump, pres. reg.) that i am going to get except the injectors. so what should i get? i have a 93 gsr so my injectors are saturated...... should i switch over to p/h? i would like to order injectors soon
Old Mar 10, 2002 | 06:31 PM
boosted hybrid's Avatar
Default Re: what injectors should i get? (93B17A)
I would just covert to low impedance with the resistor box. You are going to want large injectors, personally i am going to go with 720cc ones. You wont be hitting the max duty cycle on those suckers till around 500whp. The best price on them is from http://www.roadraceengineering.com, they run 440.00 for the 4 and then another 14 for the o-ring set. 720cc are probably overkill, but you are insured that you will never need to buy bigger injectors. Also you will not need to buy a fuel pressure riser with 720cc's. As long as your standalone has the ability idle large injectors then go for it.
Old Mar 10, 2002 | 06:45 PM
ekb18c's Avatar
Buy RC or Venom. RC tends to be a little more then Venom injectors.
Old Mar 10, 2002 | 06:56 PM
93B17A's Avatar
Default Re: what injectors should i get? (boosted hybrid)
is the EMS or hondata 4B capable of this?
and i know i would need a resistor box for bigger injectors, now if i get a box off a 90-91 integra is it a wiring nightmare?
Old Mar 10, 2002 | 07:46 PM
The hondata and ems are both capable of idling and controlling very large injectors. Check out this link to find out about doing the wiring: http://www.hondata.com/techinjector.html.
Old Mar 11, 2002 | 08:44 AM
93B17A's Avatar
"file not found"
Old Mar 11, 2002 | 11:41 AM
Just go to http://www.hondata.com, then look under the "tech", then click on "injector info and wiring".
Jeff
Old Mar 11, 2002 | 12:20 PM
93B17A's Avatar
i found it after a little browsing thanx a lot
Old Mar 11, 2002 | 12:29 PM
SIK IN DA HED's Avatar
New User
Default Re: what injectors should i get? (ekb18c)
no they dont. i got a quote for the venom 440s for $340. i got a price quote for the rc 440s for $320.
wannarace07
Jan 29, 2007 08:25 AM
mprelude
Nov 27, 2004 03:25 PM
