FI a 94+ LS motor for turbo?
hey
Can someone please help me out! I am wondering how I can build a LS motor to handle turbo with out blowing it up. If you can...tell me the parts i will need, what brand to go for? websites that may help? or a shop in VA/Dc/MD area that rebuild motors? and how much?
thanks!
thanks!
Will you make something up for me please?
Re: FI a 94+ LS motor for turbo? (Slow_ass_4dr)
If you have $$$:
JE pistons
Crower rods
Golden Eagle Mfg. Resleeving
JE Blockguard
Hondata 4b
RC 550+cc injectors
ARP head studs
Inline Pro Headgasket
New valvesprings/retainers
Ferrera titanium valves
Makes for a very happy motor and a very happy driver.
Did I forget anything?
JE pistons
Crower rods
JE Blockguard
Hondata 4b
RC 550+cc injectors
ARP head studs
New User
Re: FI a 94+ LS motor for turbo? (CivicHB_92)
there is not need for a rebuild for relatively low boost on an LS...I think you could safely boost 12psi daily, if you have correct tuning. To run this daily, I would buy a standalone, although not needed, you could easily turn up the boost to even higher, seeing as how the LS is a low compression motor. Don't let people fool you into thinking you need to completely rebuild to run boost. Put it this way, if you don't build your engine, and it's not tuned, KABOOM! If you build your engine, and it's still not tuned, guess what, KABOOM with $5,000 worth of parts! Depending on what you wanna boost, I would almost always reccomend standalone tuning before compeletely rebuilding with strong internals. Mind you, they never hurt anyone (usually )
give us an idea of how much you wanna boost?
Re: FI a 94+ LS motor for turbo? (outlawtas)
ummm...so a stock LS can handle 12 psi? how do you tuned the engine?
and what is standalone?
and what is standalone? how much?
Go here. This will tell you all you need to know about turboing your LS.
http://www.cdtl.nus.edu.sg/Ideas/iot10.htm
Re: FI a 94+ LS motor for turbo? (shamoo)
If you have $$$:
JE pistons
Crower rods
JE Blockguard
Hondata 4b
RC 550+cc injectors
ARP head studs
JE pistons
Crower rods
JE Blockguard
Hondata 4b
RC 550+cc injectors
ARP head studs
and a blockguard isn't necessary if you're getting the block sleeved by GE.
the inlinepro headgasket isn't necessary as well since you'll get the pistons at the compression ratio you want. it is only necessary if you have a stock block and want to lower the compression ratio to avoid detonation.
i'm not sure if ferrea even makes titanium valves but, if they do, that would be overkill and stainless steel would be fine.
Re: FI a 94+ LS motor for turbo? (93LSivic)
Oh, I know lots of it was overkill....I just got happy listing things. Hehe.
I have JE's blockguard in my car. Got it from Importparts. Their site lists a Nuformz guard, but the person I talked to said it was JE. It also looks different than what's pictured on the site.
Ferrera does make cyro-titanium valves too. My friend has two sets of these in his basement. I drool over them everytime I see them. Again, overkill, but what the hey.
New User
Are u sure the blockguard that importparts carries isnt a JG blockguard, i believe thats what they told me............which is why i didnt get theirs.
call inline pro(springfield, virginia) and talk to them. your finances will have everything to do with how much power you end up making and how you make it. you can run 12 psi cheaply w/ your stock block, a t3/4 turbo kit, afc, fmu, injectors. if you have more to spend, then you will be able to make more power.(built motor, standalone,bigger turbo)
inlinepro - 703-644-1788
Re: FI a 94+ LS motor for turbo? (jinxproof99)
thanks for the info guys.
yeah i live about 30mins away from them, i been to there shop before and its real nice with tons of cars being fixed up, yeah ill give them a call, but i need to find a place to do the LS swap in my hatch =p
New User
ummmm...that site dont say anything about turboing LS, or anything about cars...or am im lookin at the worng place? or?
