Argh. Threw a code I can't decode.. HELP!!
Old Mar 7, 2002 | 03:24 PM
echo999's Avatar
New User
Default Argh. Threw a code I can't decode.. HELP!!
I just got 9 flashes from the OBDII trouble codes, and I don't know
if it's consider 9 fast ones, or 9 slow ones...
so it's either 90 or 9.
90 = EVAP system leak detected in fuel tank/canister area
9 = Cylinder position sensor intermiitent interruption/no signal.
Anyone know how long (in seconds) is a long pulse? and short?
[Modified by echo999, 12:35 AM 3/8/2002]
Old Mar 7, 2002 | 03:31 PM
JM Performance's Avatar
Default Re: Argh. Threw a code I can't decode.. HELP!! (echo999)
fast ones are fast (about 2 per second) and slow ones are nearly a second long.....you should be able to tell.
Old Mar 7, 2002 | 03:34 PM
echo999's Avatar
New User
Default Re: Argh. Threw a code I can't decode.. HELP!! (00SilverLS)
Ok.. then I got a 90.. IDEAS on this one?
Anyone ever get this code? what causes this exactly?
Fuel tank leak? Fuel canister (what is this? the filter?)
Old Mar 7, 2002 | 03:59 PM
MackSpeed-616's Avatar
tighten your gas cap and reset
Old Mar 7, 2002 | 04:01 PM
boost killz's Avatar
New User
Not sure but if someone can confirm I think it could be as simple as you leaving the gas cap slightly opened, but not to sure. Just reset the ecu and seeif it returns after checking what may contribute to that code. Wish I could help more on this one.. Good luck man
Old Mar 8, 2002 | 03:44 AM
EE_Chris's Avatar
Default Re: Argh. Threw a code I can't decode.. HELP!! (boost killz)
Heres the lowdown:
OBD-II requires that a hole 0.040" be detected in the EVAP lines. This is to keep the gas tank fumes from escaping to the atomsphere.
How does it do this?
Well, you have a Gas Tank Pressure sensor. The ECU will close off the Purge Control Solenoid, so that fumes can NOT get to the Charcoal Canister. When this happens, pressure begins to build in the tank. The ECU is monitoring the Gas Tank Pressure sensor to see if theres a DROP in pressure, which would indicate a hole has been found. However, the gas cap is integral to this test too...so if its off, or can't hold a seal, then it either needs to be tightened or replaced.
Ever go to have emmisions done on your car...and when you get there they take the gas cap off...what do you think there checking for...that it holds pressure.
coolhandluke
Aug 15, 2008 03:19 PM
98slvrcx
Aug 1, 2003 10:49 PM
Aaron M
Mar 17, 2003 11:47 AM
People_Mover
Feb 12, 2003 12:29 PM
Nikos
Sep 25, 2002 02:36 PM
