So I did a search.......FMU
I looked at the diagrams that I found and it says that you need to run a line from the bottom port on the FMU to the fuel tank itself!! Do you actually have to run a line all the way back to the tank, or can you just run a line from the bottom port to the fuel feed line(the metal pipe on the fire wall)?? My hard fuel line is already cut, so couldnt I just tap into that? It seems like it would do the same thing....
Re: So I did a search.......FMU (SlowB16)
for the line on the bottom: undo the fuel line from the stock FPR (fuel pressure regulator) and connect it to here.
for the line in the side port, install a fuel line back to the stock FPR, you took off for the bottom port
top port: vaccum lines
stan
stan
Re: So I did a search.......FMU (Flamenco-T)
So ----- Fuel line to FPR --> bottom line of FMU --> side port of FMU --> disconnected FPR......correct?
[Modified by SlowB16, 7:14 AM 3/6/2002]
(fuel line to FPR) goes to the bottom port of the FMU
get another fuel line about a foot, connect the side port of the FMU back to the FPR
