Actual boost is different from controller settings?
Old Mar 5, 2002 | 11:56 AM
cool's Avatar
Default Actual boost is different from controller settings?
What could could be possible reason's why my actual boost pressure is
reading higher that what I set on my AVCR? Should WG spring be all the way down or up?
I have boost set for .5bar and duty cycle 30% and the electronic boost
controller reads 1bar under full boost????
One other thing, on the greddy blowoff valve type-s, the top hose goes to
manifold vacuum, where does the smaller bottom hose go to?
Any suggestions or tips appreciated.
Old Mar 5, 2002 | 12:12 PM
rtype11's Avatar
Default Re: Actual boost is different from controller settings? (cool)
both should read off the same vacuum source for the same reading if you have one before IC and one in Manifold there should be a small psi difference
IN VTEC
Feb 13, 2008 07:07 AM
18gsir
May 26, 2006 12:41 AM
pip9
Sep 24, 2004 09:17 AM
hXc-DC2
Oct 15, 2002 06:38 AM
echo999
Oct 3, 2002 07:41 PM
