DIY Wideband O2
Old Mar 9, 2002 | 02:42 PM
fastestdriver's Avatar
Default DIY Wideband O2
Has anybody got there DIY wideband up and running yet? Give us all an update on how it's going!!! Thanks
Old Mar 9, 2002 | 05:21 PM
boosted hybrid's Avatar
Default Re: DIY Wideband O2 (fastestdriver)
Still waiting for mine. I have the oxygen sensor, and the bung already welded...
Old Mar 9, 2002 | 05:27 PM
GruvyTune's Avatar
New User
got mine up and running, will be wideband tuning my car with the Hondata this week hopefully!
Old Mar 9, 2002 | 06:09 PM
tegman2's Avatar
Default Re: DIY Wideband O2 (GruvyTune)
Could you post a pic of it assembeled? The display and the wb controller. I got mine but still need to assemble it. The instructions arent really that clear.
Thanks,
Aron
Old Mar 9, 2002 | 06:54 PM
LsTurbo91's Avatar
Default Re: DIY Wideband O2 (tegman2)
I've got mine working and operational, its ****** great man . I have the same a/f ratio that I was getting on the dyno w/motec plm. I thought it was gonna be off by bit but it suprised the **** out of me. Only drawback is the display. Can't see during the daytime, at night it auto dims automatically and you can't see it too well because its too dim. I've done a couple of tunes for pump and race gas. Its definitely worth $300 hell even $500 would have been good. It gets a
Old Mar 9, 2002 | 07:17 PM
GruvyTune's Avatar
New User
Default Re: DIY Wideband O2 (LsTurbo91)
didn't you adjust the trim for the display illumination? Its pretty bright at maximum. Do you have a 4 digit voltmeter? Its hard as hell to get pinpoint trim on the lower limit trimpot, wasn't it??
Old Mar 9, 2002 | 09:58 PM
LsTurbo91's Avatar
nope, I had him assemble the unit, its an option now so i don't know what your talking about hehe. How can i disable it, even at maximum I can't see it because you can see the number LED 8. If i explained that well, sorry im sleepy.
Old Mar 9, 2002 | 10:30 PM
GruvyTune's Avatar
New User
you turn the adjustment trimpot so it is brighter.
Old Mar 10, 2002 | 06:37 AM
Who do I need to get in contact with to get an assembled one? How much did it cost? This is probably a stupid question but....when I get Hondata will the WBO2 actually "plug in" to the Hondata?
Old Mar 10, 2002 | 07:16 AM
GruvyTune's Avatar
New User
the hondata reads off the ecu. you will make a connector to go into the stock o2 sensor plug. then the hondata will read it as lambda values after you enter the voltage to lambda points into the romeditor program.
everythingwentblack
Nov 4, 2009 08:15 AM
C_Rock77
Engine Management and Tuning
May 11, 2008 03:41 PM
prelude_93vtec
Nov 26, 2007 07:23 PM
Tyler_Durden
Jun 13, 2003 06:36 PM
Westrock2000
Feb 25, 2002 05:20 PM
