cylinder compression ?
Old Mar 8, 2002 | 06:31 PM
98civicEX's Avatar
Default cylinder compression ?
car: 98 civic ex
mods : greddy turbo at 5.5 psi
? : is 150 for all 4 cylinders normal? is this # low at all? i haven't touched the timing of the cam shaft. the ignition is retarded 3 degrees and the spark plugs are gapped at .32
Old Mar 9, 2002 | 09:39 PM
Bnjmn's Avatar
Default Re: cylinder compression ? (98civicEX)
150 seems a little low- depends on what compression you are running though.
If they are consistent that is of greater importance.
Ben
Old Mar 18, 2002 | 01:52 PM
ATurboCivic2NV's Avatar
how many times did you crank it over?
Old Mar 27, 2002 | 06:52 PM
98civicEX's Avatar
Default Re: cylinder compression ? (ATurboCivic2NV)
7 times, WOT
EdwinCheng
May 8, 2014 02:26 PM
FalconMan
Sep 15, 2004 02:56 AM
Qwikrex
Apr 11, 2003 09:08 PM
b18c5T
Jan 29, 2002 09:08 AM
nugget8000
Aug 13, 2001 09:51 AM
