Fuel Line Sizing
Old Mar 6, 2002 | 10:57 AM
bQQsted hybrid's Avatar
Default Fuel Line Sizing
I am in the process of upgrading my fuel system. Right now I have 550cc injectors, STR fuel rail and a PMS. I was looking into the walbro 255 lph pump, Aeromotive FPR, and -6 AN fuel lines in the engine bay, but now I'm wondering if I should go with something bigger. Would a Paxton pump and regulator with -8 AN or -10 AN lines throughout be overkill? I'm going to be running 15 - 20 lbs at the track and low boost on the street. Thanks.
Old Mar 6, 2002 | 11:01 AM
VaporTrail's Avatar
New User
Default Re: Fuel Line Sizing (bQQsted hybrid)
factory lines are -6 feed and -4 return, so your minimum upgrade would be -8/-6.
I'd use a Bosch or Aeromotive pump, aeromotive regulator, and the filter of your choice, with -8/-6 if you are planning on making in excess of 450whp
Old Mar 6, 2002 | 11:09 AM
93LSivic's Avatar
Default Re: Fuel Line Sizing (VaporTrail)
Ok, well then should I stay with my bosch inline since I plan on doing the same exact setup as bQQsted??
I thought that there was no need for such a high pressure pump with the use of large injectors like the 550s
attack666
Jul 11, 2010 04:46 PM
JLHDOHC
Feb 10, 2007 08:16 PM
vr6chris
Nov 5, 2005 05:30 AM
hpfsi
Nov 7, 2003 07:01 PM
CRXBart
Jan 23, 2003 05:54 PM
