Max psi that can run
Old Mar 29, 2002 | 08:42 PM
Hybridhonda10's Avatar
Default Max psi that can run
I want to know what is the highest PSI ofboost that can be ran on a B18C with 9:1 compression JE Piston.
Old Mar 29, 2002 | 10:25 PM
BoM's Avatar
BoM
Default Re: Max psi that can run (Hybridhonda10)
depends on your fuel setup
bigger injectors and hondata
or a FMU and AFC
Old Mar 29, 2002 | 11:51 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Max psi that can run (BoM)
5psi
Old Mar 30, 2002 | 12:01 AM
turbocoupe's Avatar
Default Re: Max psi that can run (Arturbo)
or 0.35714285714285714285714285714286 bar.
Old Mar 30, 2002 | 01:50 AM
01geeser's Avatar
New User
Default Re: Max psi that can run (turbocoupe)
dont boost you'll blow ur motor!
Old Mar 30, 2002 | 03:08 AM
Dee's Avatar
Dee
Default Re: Max psi that can run (01geeser)
You can boost as high as you want atleast once...
b00sted_GS-R
Aug 27, 2004 01:13 AM
JDM_Risa
Feb 12, 2004 07:04 AM
NOSED_CRX_VTEC
Oct 5, 2003 04:25 AM
Acura_I-RS
Aug 19, 2003 04:03 PM
Spoold_R
Jan 11, 2003 02:36 PM
