injector size in a boosted applications
Old Apr 2, 2002 | 03:43 PM
Hybridhonda10's Avatar
Default injector size in a boosted applications
How do you figure out whart size injectors you should upgrade to when you boost.
Old Apr 2, 2002 | 03:51 PM
Sonny's Avatar
25 Year Member
Default Re: injector size in a boosted applications (Hybridhonda10)
The tech page on RC Engineering's web site is a good start. Injector size goes hand in hand with fuel pressure. You can run tiny injectors like the stock ones and run insane fuel pressure (via an FMU). That is the most common approach in bolt-in kits and is generally not safe for the fuel system long term.
Before I switched over to a standalone, I was running the stock JRSC kit. I made ~175whp on my 2K Civic Si using the stock 240cc fuel injectors and 105 psi of fuel pressure and an annoying Walbro in-tank pump.
After I switched to Hondata and upped the boost from 6psi to 8psi, I made ~215whp using 440cc injectors and 50 psi of fuel pressure with the stock fuel pump.
440cc injectors will support about 250 whp at "reasonable" (say 60 psi max) fuel pressure.
Sonny
Old Apr 2, 2002 | 06:57 PM
Default Re: injector size in a boosted applications (Sonnyballs)
Well I am thinking about dropping a Turbo B290 into a 5g Civic or a Del Sol. and I am trying to find out everything that needs to be changed or upgraded.
Old Apr 2, 2002 | 08:35 PM
CashedEG's Avatar
what is a B290??
Old Apr 2, 2002 | 10:46 PM
SIK IN DA HED's Avatar
New User
Default Re: injector size in a boosted applications (CashedEG)
what is a B290??
i think its a B20 and a SR20DET hybrid?
Old Apr 3, 2002 | 05:11 AM
Sorry no B290 just B20 i misstyoed it sprry.
Old Apr 3, 2002 | 07:39 AM
CashedEG's Avatar
oh ok, I thought it was something crazy. Anyways the size injectors you will need all depends on what you set up is. Built motor?? how much boost?? Are you going to run a fuel controller or stand alone?? What size turbo?? The best thing to do is have your plan ready, then go to the RC page and go from there.
s.cha
Jul 10, 2010 11:29 PM
mitchell_2kSiR
Engine Management and Tuning
Feb 6, 2009 09:08 PM
ArtNerd
Jul 26, 2006 09:08 PM
DIRTYsouthBB6
Apr 9, 2006 10:10 AM
buda18
Nov 10, 2003 06:46 PM
