Inline fuel pump for turbo
Old Apr 2, 2002 | 02:19 PM
shadowdawn's Avatar
Default Inline fuel pump for turbo
I am running stock fuel pump with Vortech FMU (assuming its the 12:1 disc). I would really like to go with a walbro 255 as I know how that install is done and there are no mods needed to put it in, just drops in.
I was recommended to either get bigger injectors with my setup OR a inline fuel pump. My question is I don't know the part # or any info on which inline I should be going with. If anyone can link me to a site selling exactly what I need or a part or model number, I'd appreciate it.
Also can you resolve this myth I was told that inline fuel pumps don't allow flow through them unless they're turned on or something wacky like that? In other words can I bolt this thing to the fire wall, plug in the fuel lines and not worry about it, and it will make sure I'm not running lean?
Old Apr 2, 2002 | 05:59 PM
shadowdawn's Avatar
Default Re: Inline fuel pump for turbo (shadowdawn)
ttt
Old Apr 2, 2002 | 07:17 PM
bmm89's Avatar
i will be selling the inline pump from my drag kit, purchased walbro in tank so won't need it i think...
gimme your email address if interested, i'll get back to you when the kit arrives(any day now)
Old Apr 2, 2002 | 10:56 PM
SIK IN DA HED's Avatar
New User
Default Re: Inline fuel pump for turbo (bmm89)
well... the inline fuel pump is better to use with your setup. i wouldnt recommend that over an intank. you have to connect power to the fuel pump of course, as well as connecting it to the fuel lines. its not a hard thing to do. either get the pump from the DRAG3 kit, or get yourself a bosche inline fuel pump. i see inlines on sale on ebay and thepartstrader.com from time to time.
Old Apr 3, 2002 | 12:04 AM
turbopimp's Avatar
Hopefully the search function is working and you can do a search on this. Many people in here consider using only an intank pump with an fmu a big no-no... remember that as pressure increases flow will decrease... most if not all intanks simply cannot supply the volume required at high (100+ psi) fuel pressure...as dlplayboy has recommended the inline Airtex pump from the DRAG 3 kit works well as does the Bosch (more expensive). If the inline is plumbed in place but not electrically connected, it will be a restriction...its no big deal to hook it up, just ground and tap the positive wire into the main relay...
Old Apr 3, 2002 | 04:41 AM
maxim's Avatar
Default Re: Inline fuel pump for turbo (turbopimp)
If you are putting in an inline fp, don't get the intank. You don't need all that fuel with your 12:1. I gaurantee you will be running rich with the 12:1 right off the bat, so don't worry about the intank until you get Hondata + larger injectors or something.
Old Apr 3, 2002 | 12:12 PM
shadowdawn's Avatar
Please does anyone have a part # or info on how much lph I need on an inline??
Old Apr 3, 2002 | 10:42 PM
turbopimp's Avatar
think Ben at Import Parts.Com can help you out...
Old Apr 3, 2002 | 10:50 PM
shadowdawn's Avatar
I'm looking to get a MSD inline pump now, ordered it already.
Old Apr 3, 2002 | 10:57 PM
voltronR34's Avatar
pressure alone is not what you want. you need the volume. intank, inline, and lower the fmu disk to prevent running to rich. try to keep a balance and avoid really high fuel pressures.
Old Apr 3, 2002 | 11:14 PM
shadowdawn's Avatar
Default Re: Inline fuel pump for turbo (voltronR34)
Ok while we're on the subject would I be needing to take the FMU out and apart and buying a whole new disc in order to do that? Which would you recommend @ 7 psi, msd inline, stock fuel pump, and stock injectors?
Old Apr 4, 2002 | 04:57 AM
maxim's Avatar
A 12:1 FMU and an inline pump(only) is fine for 7psi. If you must change out the disk, you should move down to the 10:1, which you can get to by opening up the top of the FMU(I assume you have a Vortech). Also if you have a AFC or a VAFC you can lean it out without messing with the FMU.
Old Apr 4, 2002 | 08:48 AM
bmm89's Avatar
Default Re: Inline fuel pump for turbo (maxim)
You can also purchase the whole fmu disk set from vortech for about $45 which is what i did, rather than pay 30 for each disk. It comes with 4-12:1 disks in increments of two i think.
http://www.vortech.com
i think
Old Apr 4, 2002 | 10:19 AM
ion_four's Avatar
So, the BBK inline pump says that it: Flows up to 50 gph (gallons per hour) at up to 70 psi
* Perfect for supercharged or nitrous-equipped cars
I'm planning on running <7psi, probably five if I have to nerve to mess with the stock actuator on my turbo (anyone have advice for that?) and I have an FPR and 290cc injectors...do I need the pump, or even the FMU? I've got an A/F gauge and Boost Gauge, so I'll be able to tell if it starts getting hairy...
PUREVIL
May 8, 2003 06:55 PM
B18C-RnVA
Dec 28, 2002 11:58 AM
CM-R
Jun 21, 2002 11:34 AM
2K1NBGSR
Feb 25, 2002 02:31 PM
Teluan
Sep 4, 2001 08:56 PM
