How much to "gap' the NGK range 7 plugs??? Please help!
I have NGK range 7 copper plugs and I'm running 5 psi of boost right now. What is a good gap for those plugs? I need to adjust my timing too any suggestions hat kind of timing I should be ruinning. By the way, I'm running very rich right now!
Thanks!
Thanks!
Re: How much to "gap' the NGK range 7 plugs??? Please help! (turbopimp)
But, I will be raising the boost to like 7 - 8 psi soon. And my timing is currently messed up, so I need to set it to something. What should I do for that setup?
[Modified by Sh4rky, 11:09 PM 4/1/2002]
Let me rephrase that... What timing is good for like 7 - 8 psi?
[Modified by Sh4rky, 11:16 PM 4/1/2002]
Re: How much to "gap' the NGK range 7 plugs??? Please help! (Sh4rky)
if you're running 92 octane, stock timing should still be ok at that boost level...if you plan on upping the boost later, an MSD BTM or J&S might be a good idea...
sporkcrx
11-16-2002 06:26 PM
