Wastegate dump pipe
Old Apr 1, 2002 | 01:56 PM
JMinSi2000's Avatar
Default Wastegate dump pipe
What did you guys with the drag turbo kit do with your dump pipe? Is it ok to just bolt the thing on or does it need to be hooked up to your exhaust somehow?
Old Apr 1, 2002 | 02:09 PM
b18bturbo's Avatar
Default Re: Wastegate dump pipe (JMinSi2000)
just bolt it on. If you want a closed loop system weld it down on the downpipe closeer to the cat somewhere in that area.
Old Apr 1, 2002 | 03:22 PM
TurboSedan's Avatar
New User
Default Re: Wastegate dump pipe (b18bturbo)
Yeah, it can be bolted on and run open fine. The problem with that is, once you hit hit full boost and the wastegate opens up any living creature in the immediate vicinity will have the **** scared out of them! The more so the higher you boost!
Old Apr 1, 2002 | 06:00 PM
turbopimp's Avatar
yeah, just run it open... more HP, plus it sounds *kewl*...
Old Apr 1, 2002 | 06:30 PM
JMinSi2000's Avatar
Default Re: Wastegate dump pipe (turbopimp)
How loud is it when you're just cruising?
Old Apr 1, 2002 | 06:46 PM
Flamenco-T's Avatar
when you;re cruising, you're on vaccuum, wastegate is closed on vaccum, so nothing is going thru the dump tube
at wide open throttle..then it;s different story, I call it a V8 on crack..
check this vid out...go get real player..from http://www.real.com
http://turbomafia.com/Arturbo/direp9...0by%20DIRep.rm
stan
PS: that's me..
Old Apr 1, 2002 | 07:49 PM
CRXRageD's Avatar
My dump pipe just heads straight down just below teh front of my engine. You can hear the wastegate flutter when it opens during normal driving. I like the sound but it isn;t very loud even when I'm boosting hard. Thing is I really don't like my deltagate because I have to warm up the car for like 8 mins before the damn thing will open. Does anyone have this problem with the wastegate taking forever to open?
Old Apr 1, 2002 | 07:51 PM
Flamenco-T's Avatar
Default Re: Wastegate dump pipe (CRXRageD)
hmmm no, I don't boost until the temp is normal..(halfway)
Old Apr 1, 2002 | 08:07 PM
CRXRageD's Avatar
Default Re: Wastegate dump pipe (Flamenco-T)
hmm, my wastegate is a delatgate with a 7lb spring. it won't usually open until around 180 degrees F. What kind of wastegate are using and what would you reccomend, because I am getting to the point of where I;m ready to toss this thing for something better. I am still unsure as what to get though. Suggestions?
Old Apr 1, 2002 | 08:09 PM
Flamenco-T's Avatar
get TIAL...
proven time after time...
Old Apr 1, 2002 | 08:10 PM
SIK IN DA HED's Avatar
New User
get a tial wastegate.
Old Apr 1, 2002 | 08:12 PM
New User
Default Re: Wastegate dump pipe (97CivicFerio)
v8 on crack is a good way of puttin it. it sounds cool, though... kinda like...
vrrrrOOOOOOMMMMMSSSHHHHHHHIIIIIIIIIIIIIIIISSSHHHHH HH BLLLLLAAAAAATTTTTTTTTTTTTTTTTTTTTTTT TAT ATATTATATA TATATATATATTA!
Old Apr 1, 2002 | 08:14 PM
Flamenco-T's Avatar
Default Re: Wastegate dump pipe (dlplayboy)
hahaha, sometimes I used to smile while driving just hearing it...hahahahah
I am a turbo nuts....there's should be a disesae named after me..
stan
Old Apr 1, 2002 | 08:17 PM
CRXRageD's Avatar
excellent now i have an excuse to upgrade. You wouldnt happen to know what minimum spring pressure I should get do you? I currently run 12lbs all of the time, but thining of boosting the car up to 20lbs in the end. I like to sound of my blow off valve, greddy type S. I was wondeirng if I should go HKS super seq. hehehe.
Old Apr 1, 2002 | 08:21 PM
Flamenco-T's Avatar
hmm I think the lowest one is .3 bar..~4.5psi
Old Apr 1, 2002 | 10:05 PM
DragII's Avatar
25 Year Member
closing my loop tomarrow
after 2 years...I'm fawking tired of hearing it. quiet ownz.
Old Apr 1, 2002 | 10:50 PM
New User
stan
i got TURBO FEVER. thats whut i call it. hehe
dude, i grin like an evil muthafocker when i gun it with my open dumptube and people turn their heads hella fast lookin scared out of their *** walkin along the sidewalk. its even funnier when im on the freeway and i downshift on cars next to me. pwahahahHHAHAHAHAHAHAHAHAHAHAAHH!
Old Apr 1, 2002 | 11:20 PM
servion's Avatar
The thing I don't like about my drag wastegate dump tube is that is dumps its exhausts right on my intercooler piping and oil return pine.... anyone else think this might hurt my performance?
Old Apr 2, 2002 | 01:27 AM
Dee's Avatar
Dee
Default Re: Wastegate dump pipe (servion).. big pic
Here's mine:
Sorry guys, this will be my last pic for the day!
Old Apr 4, 2002 | 08:05 AM
TurboSi's Avatar
Default Re: Wastegate dump pipe (servion).. big pic (Dee)
Has anyone ever tried to add any type of muffler, or baffle to reduce the sound of the wastegate? Or, do you all just leave it open, or run it back into the exhaust pipe?
Old Apr 4, 2002 | 08:17 AM
X2BOARD's Avatar
Default Re: Wastegate dump pipe (TurboSi)
I had come up with the idea of throwing a rice-o-nator on my open dump tube and REALLY make some noise !
Old Apr 4, 2002 | 08:22 AM
93LSivic's Avatar
I think I heard somewhere about people putting lawnmower mufflers on the end of the dump tube. I have no idea how well it worked though. I would think maybe since the muffler is there you would get a little boost creep from it not allowing the wg to fully open. But maybe not, who knows? Anyone care to give it a try and let us know?
GSE980
Welding / Fabrication
May 14, 2009 10:34 AM
dagle
Feb 9, 2008 12:51 PM
grnhatch94
Dec 11, 2005 07:23 AM
BodyKits NW
Nov 3, 2003 12:30 PM
