Who said dsm 450s fit in 88-89 DOHC teg seals?
New User
I have the DSm 450cc injectors and someone here said that they will fit in the 88-91 DOHC teg seals.
Well I have the 89 teg seals and they are the same diamter as the stock 88-91 CRX seals.
Who knows for sure what injector seals have a bigger diameter and fit the 88-91 CRX intake manifold?
Please reply,
Randy
Please reply,
Randy
Re: Who said dsm 450s fit in 88-89 DOHC teg seals? (RGAZ)
randy,
im the one that said the seals work, i am using them in my car right now!! its not the inside diameter, that matters, it is the thickness of the seal, dont try to put the whole tip of the injector into the seal just the bottom little lip, i hope you can understand what i am trying to say here
thanks
brian
thanks
brian
New User
Re: Who said dsm 450s fit in 88-89 DOHC teg seals? (TurbodCX)
I see what you are saying. Are you sure they will seal good enough? I don't want positive pressure leaking from the seals when under boost.
Thanks for the reply.
Randy
Randy
Just bore them out with a rasp or dremel. Or, send me your stock seals and $20.00 and i'll send them back to you done.
importdude2000
04-20-2006 12:50 PM
