turbo question
Old Mar 29, 2002 | 02:45 PM
civteg1's Avatar
Default turbo question
which turbo kit do you guts think is better revhard or f-max I can't decide. Or what would you guys recommend
Thanks
Old Mar 29, 2002 | 02:47 PM
falcongsr's Avatar
What is this crap?
Default Re: turbo question (civteg1)
you should have made this a poll.
Old Mar 29, 2002 | 03:33 PM
dustin's Avatar
Definately JRSC, check my sig.
Old Mar 29, 2002 | 04:13 PM
Dee's Avatar
Dee
Default Re: turbo question (dustin)
Here's how you get 600hp with no problems! Weind 12-71 blower with Holley dual 1050 dominators, Crane 1.7 ratio roller rocker arms, Comp Cams roller lifters, 312degree .620 lift Iskederian camshaft, Trckflow chromoly pushrods, Manley Valve spring/spring cups/locks/retainers, Milodon 2.250/1.88 valves, Jesel gear drive, Merlin Aluminum heads, Dart Big M big block, Lunati crank with Keith black pistons/Manley steel rods and Fluidampr, Stef's 7qt Aluminum oil pan and oil pump, Magnastar pro 500 pump with filter, Meizere electric water pump, MSD 8 ignition with crank trigger Pro power coil and Pro Mag. Couple this to a Hurst Quarter stick shifted TCI built Turbo400 tranny with a 10" street fight stall converter and a Strange 9" Ford rear pumpkin with Richmond 4.86 gears and Strange Spool you shouldn't have any problems beating people at the track. If you want I can list the complete setup since I left out a few things.
You were talking about a Big Block Chevy right?
Old Mar 29, 2002 | 05:21 PM
cyan1de's Avatar
tornado intake + jrsc = 30psi on stock block
Old Mar 29, 2002 | 05:23 PM
Tomakit's Avatar
Thanks
Funny how this thread is still active when this thread was created...
FMAX or Revhard?
https://honda-tech.com/zerothread?id=153036
Tom
XxINLINExX
Jan 11, 2009 10:44 PM
BlangBlangTEG-93'
Jan 16, 2007 05:58 AM
Drag-Accord
Dec 25, 2004 12:52 AM
dAng! Kris
Nov 19, 2003 04:51 PM
immortal
Feb 23, 2002 09:44 AM
