Intake Air Temps
Old Apr 2, 2002 | 08:25 PM
racerxadam's Avatar
Default Intake Air Temps
Well my air/water intercooler is on the way and I am wondering how it will compare to a large fmic. Does anyone have numbers for short term and long term. In other words, "when i first start out in the morning my iat's are ___ and after i've been at full operating temp for a half-hour my iat's are ___." I don't really need all that. any info would be greatly appreciated
Old Apr 3, 2002 | 04:21 AM
racerxadam's Avatar
Default Re: Intake Air Temps (racerxadam)
Old Apr 3, 2002 | 04:53 AM
RGAZ's Avatar
New User
I will check with my friend. He is running a starion IC on a 8psi D16A6 CRX si.
he has intake temps to share.
I will post them here.
Randy
Old Apr 3, 2002 | 06:38 AM
b18bturbo's Avatar
Default Re: Intake Air Temps (RGAZ)
you air temps adam with the air to water should be around 50-80degrees depedning if you load it with ice. It shouldnt go past 100 degrees if it does then its loosing its efficiceny.
Old Apr 3, 2002 | 07:27 AM
austrian type-R's Avatar
Default Re: Intake Air Temps (b18bturbo)
I did a WOT run in 5th gear on a 3% uphill on the Autobahn
Boosting 1.25 Bar for about 10 seconds
The temp out was about 15 degrees Celsius and the Haltech intake temp sensor showed 25 deg. WOW!
This was with the DRAG 3 intercooler.
EDIT: My turbo is watercooled. This should help a bit too.
[Modified by austrian type-R, 5:29 PM 4/3/2002]
Old Apr 3, 2002 | 08:11 AM
RGAZ's Avatar
New User
Default Re: Intake Air Temps (austrian type-R)
Here is what he said.
Well, what I've noticed with the IC is that the intake temperatures are related primarily to the speed I'm traveling and the ambient air. Obviously, when I first start the car, the temperature is the same as the ambient air. If I'm traveling at residential speeds, the temperature will usually get up to 100-110F. When cruising on the freeway, it would get as low as 10-15 degrees over ambient. During the autocross we went to, I don't recall seeing any temperatures over 115-120, but I could be wrong. Now, when you are stopped, the intake temperature climbs quickly. After I've parked the car, I've seen the temperature shoot up to over 140 and it takes quite a while for it to come back down.
There you go. Not really load dependant, but ambient air makes a big difference.
Randy
Old Apr 3, 2002 | 08:33 AM
racerxadam's Avatar
thanks guys.
compint
Sep 15, 2006 11:05 AM
Hackdawg2
24
Jul 18, 2004 05:46 AM
MiraiZ
Jul 24, 2003 07:04 PM
johnisenglish
Apr 22, 2003 06:35 PM
The_Head
Dec 15, 2002 11:28 AM
