Help blown engine or turbo?
Old Mar 30, 2002 | 04:04 AM
turbozc2001's Avatar
Default Help blown engine or turbo?
help guys i race this morning 400:a:m 110mph i notice slow down litle bit i start smelling burning oil and i hear puffpfuufufuf sound. I stop check my engine compartment isaw my valve filter soak oil even my blaster coil. I cant' idle i have to stay above 2000rpm i check my oil if theres a water i did not see contaminate. But i notice my exahause smokking bad.the spark plug wire still there hook up. i drove to my house another 2 mile stillmaking sound and i'm still seeing boost my oilgauge still working. guys i dont know what the problem i'll find out today in the day time. What do you thik is the turbo seal broke or the engine piston ring loss compresstion? I know theres people out here had expericence like this.
My
zc dohc stock internal
tdo5h dsm 9psi
450cc dsm
safc
thanks
Old Mar 30, 2002 | 05:50 AM
b20b's Avatar
New User
Default Re: Help blown engine or turbo? (turbozc2001)
I don't think it's the turbo. If your still seeing boost, mostly likely your motor. take off your valve filter, is there blow by?(smoke coming out of there?) moer details
[Modified by b20b, 6:53 AM 3/30/2002]
Old Mar 30, 2002 | 07:05 AM
dbman96's Avatar
New User
Default Re: Help blown engine or turbo? (b20b)
Things I think of: Head gasket, blown ring land, hole in piston, blown rings. Other possibility is cracked cylinder wall but I don't think you'd be running that well if that were the case. Definitely not the turbo though.
Old Mar 30, 2002 | 07:37 AM
Default Re: Help blown engine or turbo? (dbman96)
hi guys i just check the turbo on the intake side by air filter got a oil in there and before goes to trotle body. I just took out the turbo out im going back non turbo mode put back my dc header, I'll give try if still running funny. I check the valve filter is not smoking or no oil coming out. before i check it i make sure had oil engine. is fin i just add one quart oil. I could feel sucking air in the valve filter. and i check the oil again if there a silver metalic came out clean. even the spark plug clean no damage. before i took the turbo out i start car idle fine just had smoke exahust. I'll give back with guys let se whats the problem. thank'sfor idea.
Old Mar 30, 2002 | 12:20 PM
1 ex and 2 ex have oil coming out. yak i think i damage piston ring...i think is time for rebuild. I dont know if want go back to turbo mode after the bad experience had today. I been boosting for 4 months i love turbo but today sucks i have no car and no more trill 1/4 mille for next week. thats why i call it stock zc suck. i might go allmotor zc bigger compresstion. more power to all FI guys!!!!!! Thanks again here we go again project baba..
Old Mar 30, 2002 | 02:11 PM
Ri5e's Avatar
hey...it happens. =P
bnmm
Apr 19, 2012 07:32 AM
EvOsweenS
Sep 29, 2007 09:22 AM
95civ
Jul 15, 2005 09:07 AM
gdrum
Sep 10, 2003 02:02 PM
_Endless_
Apr 26, 2003 07:04 AM
