Do you have to use water cooled or can you skip it and just do Oil?
i dont really want to run the lines but if i have to then i will. I want to just run oil lines ant thats it.
Re: Do you have to use water cooled or can you skip it and just do Oil? (CIV616)
You don't have to, its up to you. Mine has a water cooled center section and I did not hook it up. I was told by Majestic that the oil chamber is bigger, which is true.
Re: Do you have to use water cooled or can you skip it and just do Oil? (integracon)
what would or could happen if i dont use it?
nothign happens if you dont use it. Just plug it up and call it day. Its better to use it though if you got it.
Re: Do you have to use water cooled or can you skip it and just do Oil? (b18bturbo)
if i sue it where should i put th elines for the in and return line?
i would just use the lines set up for the TB heater. you may have to run them a longer but at least there is no splicing involved. besides this will help cool down the turbo alot better then the oil will. hell if you dont want to hook it up i will trade center housing i have a fresh rebuilt center for a t3. i will pay for the shipping and everthing!!
