defying physics
Old Mar 29, 2002 | 05:34 AM
exavtgsr's Avatar
New User
Default defying physics
Type C and I made two different mbc's for my car,
the first one, (ball and spring) would either run of the wastegate spring, or boost whatever the turbo could boost.
the second, (bleed type) actually moved the boost up to .9 bar, but then it fell back down to .5 bar after hitting the peak, and then never would spike back up to .9bar in any gears afterwards. WTF !!!!
I can't just drive around at .5 bar boost, and i don't have the money for an ebc.
Could the waste gate arm be getting stuck after it opens? Has anone ever had this problem?
BTW, the turbo is a stock garret t-25 on an sr20det
Thanks-Billy
Old Mar 29, 2002 | 06:19 AM
falcongsr's Avatar
What is this crap?
Default Re: defying physics (exavtgsr)
sounds like the ball and spring one was not adjustable enough...not sensitive enough i mean. how was it made?
Old Mar 29, 2002 | 07:32 AM
exavtgsr's Avatar
New User
Default Re: defying physics (falconGSR)
2 little bits from home depot. various soft springs from true value, and a ball bearing from true value. It should work. I guess i can mess with it more, (diff springs)
Old Mar 29, 2002 | 07:38 AM
falcongsr's Avatar
What is this crap?
with a threaded housing that can compress the spring, you should be able to adjust preload close enough. i havent done this myself so i guess it takes a bit of fiddling. i am probly going to break down and get a $15 grainger valve.
Old Mar 29, 2002 | 07:52 AM
G's Avatar
G
A stiffer spring solved my problem. I also made a tiny hole on the WG side of the MBC. It relieves the pressure when the ball is closed. The MBC acts as a check valve in the opposite direction. Fiddling is the only way to tune it, lots of fiddling....
Old Mar 29, 2002 | 07:54 AM
exavtgsr's Avatar
New User
WTF is a grainger valve?
I also had a bleeder with the ball and spring to actaully hold peak boost, if i didn't have it on there the boost would fall off.
Old Mar 29, 2002 | 08:18 AM
DSF's Avatar
DSF
Something like this...
http://www.grainger.com/Grainger/pro...mId=1611729925
Old Mar 29, 2002 | 08:24 AM
exavtgsr's Avatar
New User
Default Re: defying physics (DSF)
so that is basically like the bleeder i have just a valva, what is so special to make that worth $15 instead of $.99??
Old Mar 29, 2002 | 08:40 AM
G's Avatar
G
Your bleeder + relief valve is actually the best you can do with MBC madness. The ball/spring would hold boost until a certain pressure is reached and the bleeder holds peak pressure. You had it all along, just need to tune the bleeder first then the ball/spring....
http://www.autospeed.com/A_0670/page1.html
For your reading pleasure....
Old Mar 30, 2002 | 01:35 PM
falcongsr's Avatar
What is this crap?
Default Re: defying physics (G)
i just dont get it...whats the point of that guy having a pressure relief valve AND a pressure regulator? you can set the boost pressure with just the relief valve, no?
Old Mar 30, 2002 | 04:52 PM
Hybrid's Avatar
I too was going to try the home made MBC for my turbo setup. but a pal of mine is using pressure switches for his (his are NOS switches to be exact). they are like $60.00 canadian, so like maybe 35 USD. Anyway je uses it with a stock honda selenoid a a vacume tester to set, real simple.
check it out
So basically its fool proof and accurate and safe. The waste gate see's no boost till the boost switch lets the selenoid see it.
I think all of that makes sense.
This is all with the internal waste gate on mitsu turbos, I think the stock springs are 5.5 or 6psi?
Old Mar 30, 2002 | 04:54 PM
Hybrid's Avatar
Default Re: defying physics (Hybrid)
oh yeah there are two there, one for boost control and one for his alcohol injection for intake cooling pruposes.
mhewitt
Dec 7, 2010 03:51 AM
eg:R
Mar 6, 2006 01:15 PM
Toda Party
Nov 14, 2005 06:58 AM
Taikonaut
Oct 29, 2003 11:34 AM
TurboDC4
Mar 28, 2003 10:02 AM
