turbo timer, radiator fan
Old Mar 31, 2002 | 07:50 PM
servion's Avatar
Default turbo timer, radiator fan
My radiator fan stopped turning on just recently, makng it hard to stay cool. It doesn tno come on anymore, and I checked the fuse under the hood, and it's good. Any ideas? It used to turn on, and now it doesn't.
Old Mar 31, 2002 | 07:54 PM
Tofurky's Avatar
Default Re: turbo timer, radiator fan (servion)
happened to me and a lot of other people, never found out why.
i just hooked up the fan to an on/off switch then to the battery as a temporary solution.
i'd also like to know what it could be
Old Apr 1, 2002 | 04:09 PM
servion's Avatar
Default Re: turbo timer, radiator fan (Ruckus138)
Sounds like a plan... any suggestions on how to go about doing that? Thanks
[Modified by servion, 6:09 PM 4/1/2002]
Old Apr 1, 2002 | 04:10 PM
dangerzone's Avatar
New User
just leave your A/C on...
Old Apr 1, 2002 | 06:02 PM
Tofurky's Avatar
it's not a solution but it'll work until you figure it out.
it's pretty budge and i don't recommend you use this for more than a few weeks...
just go to radioshack and pick up some wire, those little alligator clamps, an on/off switch, and some electrical tape.
just hook up a wire directly to the fan, run it through your firewall and under your dash, hook the other end to an on/off switch, take another wire and run it from the switch, through the firewall and directly to the battery.
fan goes on, fan goes off.
like i said, budge.
Old Apr 1, 2002 | 06:04 PM
Cramerox's Avatar
do u think the problem has to do with a busted thermostat?
Old Apr 1, 2002 | 06:15 PM
Nfurno's Avatar
are you saying that your fan doesn't work after you put in a tt or it doesn't work when the tt is counting down? my fan doesn't click on when the tt is counting down, but works when it needs to and i always wondered why, but really didn't worry about it too much.
Old Apr 1, 2002 | 06:17 PM
Nfurno's Avatar
Default Re: turbo timer, radiator fan (Nfurno)
i forgot to add that my a/c doesn't work either with the tt counting down, but does work when need be.
Old Apr 1, 2002 | 08:04 PM
Tofurky's Avatar
ok, well if it is working other times then i dunno what to tell you, it not working with the tt happens to a lot of people... but i had the problem where it just wouldn't ever turn but the actual fan worked, i never figured it out.
Old Apr 1, 2002 | 08:10 PM
CRXRageD's Avatar
Ever considered a bad thermoswitch?
Old Apr 1, 2002 | 08:13 PM
AlphaKennyWun's Avatar
Default Re: turbo timer, radiator fan (CRXRageD)
my fan doesnt work with the tt either. I just leave the AC on and sit in the car for a minute. Been meaning to find a way to fix that.
Old Apr 1, 2002 | 08:21 PM
servion's Avatar
Default Re: turbo timer, radiator fan (SO3Burner)
just changed the thermostat... did the trick.
Thanks, all
Old Apr 1, 2002 | 08:24 PM
CRXRageD's Avatar
Cool
Old Apr 1, 2002 | 10:53 PM
Cramerox's Avatar
didmt i just say that?
meanTheDope
21
Aug 24, 2016 09:20 AM
evoluti0n12
39
Oct 27, 2015 11:03 AM
maverick32
Jun 17, 2009 10:49 PM
em1_mark
33
Apr 21, 2005 01:38 PM
4DRmafia
Sep 6, 2004 05:19 PM
