Help on the DRAG kit
Old Apr 1, 2002 | 07:32 PM
Evil EG's Avatar
Default Help on the DRAG kit
I have a '00 Integra GSR and I have it all apart right now.
How much of the block do you have to remove...the drag instructions say a 1/4" to 1/2" but we have removed ALOT more than that. We have also cut about and inch off the radiator fan gaurd. How much has every one else cut off. Also how did you get the manifold to connect to the turbo. Cause I am putting the manifold on and then putting the turbo up through the bottom of the car and connecting it to the manifold...Is there an eaiser way? Thanks for all your help.
Old Apr 1, 2002 | 07:39 PM
Flamenco-T's Avatar
Default Re: Help on the DRAG kit (BVM)
I cut about 1/2 to 3/4 inch off the block, I still have about 1/4" of extra space for the jerking of the car from the start.
I made a round cut, use a 3/8" drill then smooth it out with a smaller drill bit...
install the turbo to the manifold first, then install the oil return flange to the turbo and the oil feed fitting to the center housing
you'll need to torqye the turbo to the manifold bolt, has to be tight, it's almost imposiible doing it with turbo from underneath...
then insert the manifold and turbo at an angle to the head..it'll fit,,just do it carefully, don;t scratch up the radiator..
Old Apr 1, 2002 | 08:01 PM
turbopimp's Avatar
The turbo has to be mounted onto the exhaust manifold first, along with the oil feed and drain lines, then the whole assembly can be dropped in from the top. This will be much easier if your buddy pulls up and forward on the ac line to make more room to drop the whole thing in. Initially leave the bolts on the center section loose so you can rotate and clock the housings to line up the compressor nozzle with the intercooler pipe and to locate the oil drain fitting. Use a permanent marker to mark the area of the block that has to be removed. A Dremel with a cut off wheel makes this a quick job...good luck!
Old Apr 1, 2002 | 08:11 PM
Flamenco-T's Avatar
Default Re: Help on the DRAG kit (turbopimp)
ooh yeah, he;s right, don;t forget to adjust the turbo shaft
Old Apr 16, 2002 | 08:14 PM
DeDonDeRosa's Avatar
Default Re: Help on the DRAG kit (Flamenco-T)
hey BYM where did you get those instructions for the kit cause i really need them bad
please help me out
thanks bro
97 GSR
Old Apr 16, 2002 | 10:57 PM
SlowB16's Avatar
Default Re: Help on the DRAG kit (DeDonDeRosa)
What do you need to know? Everything is fairly straight forward
Old Apr 17, 2002 | 01:18 AM
intekragsr's Avatar
get the instructions at importparts.com under the customer service section.
Old Apr 17, 2002 | 02:26 AM
Kamin's Avatar
Default Re: Help on the DRAG kit (intekragsr)
http://www.importparts.com/importpar...serTemplate/18
elpiar
Jun 14, 2005 07:46 PM
civicqm
May 8, 2003 02:26 PM
chris@cfranklins
Jan 1, 2003 04:35 PM
drifter
Jan 21, 2002 10:08 PM
