JRSC+Injectors?
Old Mar 29, 2002 | 12:15 PM
SlowAutoLS's Avatar
Default JRSC+Injectors?
I thought something would come up in a search but no luck. What size injectors are best for a JRSC'ed integra LS @ 6 PSI and then 8-9 PSI later? Will two different sizes be needed? Maybe get a set that will be kind of big for the 6 PSI and then just right for 8-9 PSI?? What injectors are you JRSC'ed tegs running and at what PSI? Thanks!
Old Mar 29, 2002 | 02:00 PM
BoostCreeper's Avatar
Default Re: JRSC+Injectors? (SlowAutoLS)
I used to be supercharged back in 98-99 and I spoke with Oscar Jackson at an Autorama and he gave me this list of things to do....
50lb injectors=RC
water injection =john eagle/Jackson racing
pully+belt =john eagle/Jackson racing
Fuel pump=john eagle/Jackson racing
160degree thermostat
cooler plugsbcpr6ey-11) or (bcpr7ey-11)
remove catalytic converter
at least 2- 1/2 inch piping all the way back
dc 4 into 2 -1 header.....He wrote this info on a brochure he gave me...
this set up should make your car haul-*****
boost on.....hope this info helped fuel is a good thing
[Modified by BoostCreeper, 3:01 PM 3/29/2002]
Old Mar 29, 2002 | 04:34 PM
Kendrick07's Avatar
Default Re: JRSC+Injectors? (BoostCreeper)
rc 310cc injectors. 7-8 psi
[Modified by Kendrick07, 5:35 PM 3/29/2002]
Old Mar 29, 2002 | 07:28 PM
SlowAutoLS's Avatar
50lb. injectors and water injection. How much boost were you running?
Old Mar 29, 2002 | 09:03 PM
Conechaser's Avatar
my friend is running either 270 or 290cc injectors on his jrsc gsr @ 11psi. He is a tad on the rich side still.
Old Mar 30, 2002 | 04:14 AM
SlowAutoLS's Avatar
Default Re: JRSC+Injectors? (94Accord)
My friend is using venom 10% over stock injectors and he runs rich through out the RPM range. He is running 11 PSI.
Old Mar 30, 2002 | 07:44 AM
quikB18B's Avatar
I just ordered 310cc from ben
Old Mar 30, 2002 | 07:46 AM
SlowAutoLS's Avatar
Default Re: JRSC+Injectors? (quikb20)
quikb20, how much boost are you running?
Old Mar 30, 2002 | 09:50 AM
ronin's Avatar
i run 440cc from rc, with hondata 2b. got the jackson pump, but no boost dependant riser anymore, got rid of the jackson relay. i've got a b20 crank pulley good for 8-9 psi, but we ported the intake and run about7-8 psi instead. this runs all the way to 9k, and the hondata allows alot of control for the timing so i don't know anywhere. i still run rich over 7500, but not like i did with the stock jackson schit. i also run a kamikaxe 2.5 inch and a test pipe with mahnaflow 2.5 inch glasspack.
Old Mar 30, 2002 | 01:26 PM
quikB18B's Avatar
Currently its running 5.5 psi i believe boost gauge wont pass 5 but i think it may be slighlty off. I have a bad injector so i have a fuel leak which is hurting me right now. Plans are if it stops raining im going to go pick a b20 crank pulley.
Injectors should be here tomorrow, and then next weekend is tuning. Car is running like **** right now but it's still fast. My friend who had the blower ran a 12.9 with an ls vtec setup in his integra so were hoping for some good results as well. btw that 12.9 was 10 lbs and slicks
Old Mar 30, 2002 | 03:18 PM
SlowAutoLS's Avatar
Will the stuff that comes with the jackson kit handle bigger injectors? Hondata kicks *** but i can't get dyno tuned in my area and i'm not getting the 4b unit cuz that is way too expensive for me. I've been looking at the JRSC for about a year now and i'm finally starting to have the funds for it. How exactly does it handle fuel enrichment??
langis300
Jul 28, 2007 03:46 AM
stickshift
Aug 2, 2003 04:22 PM
Ntrpriz
May 16, 2003 02:42 PM
