Kakimoto 3" exhaust
Kakimoto 3" exhaust
Does anyone know if the Kakimoto 3" exhuast (3" piping from cat to exhaust) bolt on to a stock cat? if it doesn't which aftermarket cat would you guys recommend?
Re: Kakimoto 3" exhaust (pornstaR)
Ok, seems kinda like a dumb question but....Why the hell would you go and spend money on a 3" exhaust and still use the stock super-restrictive cat? Or is a test pipe gonna be used, and the stock cat just for emissions time? I would say either a 3" cat like a carsound (best) or test pipe
Kakimoto makes a 3"??? Does anyone have a website or anything that i could check out...I have a 95 Civc Sedan...i plan on doing B20 turbo...
The ID at the cat flange is 63mm (2.5"), so I don't think it will bolt up.
Actually, it is not a 3" catback too, it is 70mm OD b-pipe, so it is more like 2.75" OD piping. But since it is a straight thur design, it should flow good enough for a mild turbo set up!!
For more info, check out the URL at my sig.!!
Ri5e
12-05-2002 08:12 PM
