rod bearing sizing question
Old Apr 2, 2002 | 09:46 AM
Brian_92GSR's Avatar
New User
Default rod bearing sizing question
I've got one rod bearing that is measuring about .010mm too tight. What is the size difference between each color bearing? It is the number 3 rod that is too tight, and .010mm would put it in spec with the others. I believe number 3 should be a bit looser, so I'd like to get a bearing that is about .015mm smaller.
Old Apr 2, 2002 | 09:48 AM
blueciv69's Avatar
Default Re: rod bearing sizing question (Brian_92GSR)
What color is the bearing or if your not using honda bearings why is the rod different?
Old Apr 2, 2002 | 09:58 AM
New User
Default Re: rod bearing sizing question (blueciv69)
They are honda bearings on Crower rods (fully built sleeved block). I'm not at home so I'm not sure what color it is right now. I believe it is the color that corresponds to a no.3 rod with a no.2 crank. Pretty sure it was brown, maybe red.
Old Apr 2, 2002 | 10:04 AM
blueciv69's Avatar
-k- rod bearings are usually all the same color.. But what do I know I only rebuild 8 or 10 motors a month. I could be wrong though. What is specified tolerances for the clearance +/- what and what torque. Also did you get your crank micropolish or ground? This is always a biggy.
Old Apr 2, 2002 | 10:17 AM
New User
There are about 8 different color (sized) bearings. The one you use depends on what the crank and rods are sized for. I already know that my number 3 rod bearing is too tight, I just need to know if I should go one size smaller or two sizes.
Old Apr 2, 2002 | 12:17 PM
BlwnBlue's Avatar
1 size smaller! the are .01 mm difference between each bearing...plasti guage it to find out, as that is the only way to find out FOR SURE!
you are! sheez don't tell people that, you'll have a buch of people talking about how they spun a bearing cuz they used all one color...the crank has a Letter on it that corresponds w/ the number on the rod, crowers are usually rated as a #2..then you take the letter on the crank and it corresponds w/ a chart ..you can call the dealer and tell them you need a rod bearing and tell them the letter on the crank and the number on the rod...they'll tell you the color..I have the chart @ home but I'm at work now..but you still need to PLASTIGUAGE IT!
[Modified by BlwnBlue, 3:22 PM 4/2/2002]
Old Apr 2, 2002 | 01:53 PM
Doodoo's Avatar
Default Re: rod bearing sizing question (BlwnBlue)
You can use all the same color...if you re-size the rods.
aavtec
10
May 17, 2013 10:07 PM
russ.shafer
Nov 6, 2011 06:46 PM
b20ek
Jun 2, 2003 11:08 PM
Teg15
Sep 1, 2002 01:12 PM
cbmlsvteg
Aug 13, 2002 12:04 PM
