this is what i have for my set up so far.......what else do i need???
i got the greddy kit.(for sohc) intercooled with a vortech fmu 12:1 adn a holley intank fuel pump and a check valve so i don't have to use the greddy brain box. this is my set up so far. what do you think. currently on my motor i have a cam gear, pulley's and an msd ignition. any other suggestions that i should look into getting??
thanks in advance for all of the help
New User
Re: this is what i have for my set up so far.......what else do i need??? (ijustwannarace)
With a 12:1 you're going to need more than a Holley intank pump. You need something in-LINE (it takes two pumps in series to meet the pressure requirements of a 12:1 FMU). Check out the bosch inline that ENDYN sells (www.theoldone.com) if you're hooked on the FMU idea. Otherwise stick with the blue box or get a real standalone.
Re: this is what i have for my set up so far.......what else do i need??? (dbman96)
the only reson i chose this set up was because this dude did it to his hatchback and he said it worked like a champ.......he also said the blue box sux........but thanks for the opinions though i will run this by my tuner!!!
thanks guys
thanks guys
blkeg2
04-25-2004 03:52 PM
slwazgsr
10-05-2002 06:58 PM
SiBirdie
09-28-2001 09:31 PM
