Tech question: Setting TPS sensor
Old Mar 31, 2002 | 09:12 PM
boosted hybrid's Avatar
Default Tech question: Setting TPS sensor
I know this belongs in the tech section but no one seems to have answers, besides this is semi turbo related. I am swapping in my rebuilt b16a block and the tps sensor was broken while the engine was out. The throttle body was a jdm spec one with the tps sensor bolted on, not riveted on like the us spec ones so it is adjustable. I replaced the sensor with another tps that i had laying around. My question: How do you properly set up the tps sensor in the correct position so that the ecu doesnt throw a code 7 (obd-1)?
Old Mar 31, 2002 | 09:16 PM
BoostinDC2's Avatar
Default Re: Tech question: Setting TPS sensor (boosted hybrid)
when the throttle plate is closed its suppose to be at .5 and when the throttle is open its suppose to be at 4.5
Old Apr 1, 2002 | 03:23 AM
EE_Chris's Avatar
Default Re: Tech question: Setting TPS sensor (BoostinDC2)
The TPS should read about .45V, +/- .05V @ idle. However, if @ WOT it doesn't read 4.5V....tough ****. If you try to adjust for 4.5V @ WOT, it will not be .45V @ idle anymore.
So to re-iterate, set the TPS for .45V at idle and be done with it.
Old Apr 1, 2002 | 05:53 AM
Alright that is what i thought, but the readings that i get are far from that. I probably am not probing the right wire to get the readings correctly. Do you guys know what wire(s) i should probe to get the voltage signal. The book tells me the red/black wire but the readings are very off when i use his wire.
Old Apr 1, 2002 | 06:08 AM
EE_Chris's Avatar
Without citing wire color, I can tell you this: There are 3 wires for the TPS. They are the V+ (5V), Output signal, and Gnd. If you keep the black lead of the meter on ground, and probe the other two...it should be obvious which is which.
Old Apr 1, 2002 | 06:15 AM
Gotcha...that is what i was doing wrong. I was just probing a single wire and putting the ground probe to a chassis ground. I will try that and see how it works.
Old Apr 1, 2002 | 06:20 AM
Also just for clarification, the tps sensor code when thrown will put the car into limp mode. I drove the car around last night with the code flashing, and it feels to be severely limited in power output. The book doesnt say much about the cars characteristics when the code is tripped, so i was just wondering.
nutball72
Nov 11, 2006 07:14 PM
snouka
Oct 15, 2004 02:02 PM
GTlvr82
Nov 20, 2003 01:21 PM
prendi
17
Apr 29, 2003 07:38 AM
blazin
Jan 14, 2002 12:50 PM
