Oversized Valves........
Old Apr 2, 2002 | 06:15 PM
Slick GS-R's Avatar
Default Oversized Valves........
what are the benefits/advantages of getting these over stock sized valves?
Thanks in advance guys
Old Apr 2, 2002 | 08:40 PM
VaporTrail's Avatar
New User
Default Re: Oversized Valves........ (Slick_GS-R)
oversized valves enlarge the valve opening area, and allow more air to enter the combustion chamber. An excellent upgrade for turbo applications, so long as you have the fuel management to support it.
Old Apr 3, 2002 | 06:14 AM
Slick GS-R's Avatar
Default Re: Oversized Valves........ (VaporTrail)
i don't understand how this is possible.....is the valve longer or does the head of the valve have a larger circumference...can you explain with a little more detail please?
Old Apr 3, 2002 | 06:20 AM
Tomakit's Avatar
Larger circumference.
Tom
Old Apr 3, 2002 | 08:17 AM
Slick GS-R's Avatar
Default Re: Oversized Valves........ (Tomakit)
so by getting larger valves you would have to machine the head (enlarge the valve ports) correct?
Old Apr 3, 2002 | 09:52 AM
ion_four's Avatar
yeah, I'd think most shops that can do a valve job could do that, too...since it's really just an EXTREME resurfacing, hehe
Old Apr 3, 2002 | 01:57 PM
KStuned's Avatar
Default Re: Oversized Valves........ (ion_four)
as I understand it there is a downside to oversized valves.... it takes away quench area, which is what sandwiches the air into the center of the chamber for a more complete combustion. Other than that it flows more air which is always good. My friend just had 2mm oversize valves stuffed into his head, I will let you guys know how it works out.
Vtec04
Engine Machining & Assembly
Nov 10, 2017 02:23 PM
kornerk12
11
Jul 3, 2009 03:55 AM
7rrivera7
Nov 7, 2005 03:11 PM
98Psi ITR
Oct 29, 2001 03:09 PM
