need help on setup, suggestions welcomed..
Old Apr 1, 2002 | 08:37 PM
wicx's Avatar
Default need help on setup, suggestions welcomed..
ok i run a fully built b16a so running 20-25 psi shouldnt be a problem...
so as far as management i think i'm gonna go with the hondata 3b plus the upgraded map.. i was told that i could also just run the stock fuel regulator with the hondata, comments?fuel probably run the "Big one" pump by endyn and either 550cc or 750...and then as far as ignition can i squeze by with stock or just get the basic msd or jacobs? any one care sharing their setup?
thanks in advance....
Old Apr 1, 2002 | 08:43 PM
93LSivic's Avatar
Default Re: need help on setup, suggestions welcomed.. (NightKids)
You dont need the Endyn/Bosch pump, just get the Walbro 255 HP intank. Depending on what hp your looking for you can either use 550's or 720's--but from the sounds of the boost you wanna run, I would suggest 720's. Dont really need to do the ignition--stock should suffice. Remember 720's are peak and hold injectors so you will need a resistor box.
Also if your goint that high in hp and boost-then I would recommend a total upgrade on the fuel system.
Willie
May 23, 2005 12:00 PM
arsenaldragster
May 28, 2003 10:44 AM
Anubyss
May 16, 2003 05:12 AM
VisualAutoMotoring
Apr 1, 2003 07:38 PM
redline201
Dec 8, 2002 11:59 AM
