Boost Controller Tuning
Old Jan 15, 2003 | 08:15 AM
dwilson's Avatar
Default Boost Controller Tuning
I am going to turn up the boost finally. I have been running off the Tial for a couple of months to break in my motor after the rebuild. My set up is a Ls motor with Drag kit and hondata 2b for tunning. What i need to know is with the boost regulated with the Wastegate (.45 bar spring) it has only been hitting 5 psi. I had it tuned there but now i am ready to turn it up. I just purchased a standard Turbo XS manual boost controller and want to install it. My question is can i install the boost controller before i have it tuned again? I mean the Tial spring is rated at 6.5 psi., but when i had it tuned it was only tuned at 5 psi. Right. Will i be able to tune it to 6.5 now that i have the boost controller without running lean since that it what the wastegate is regulated at. I would be covering for pressure drop. Any help would be appreciated.
Old Jan 15, 2003 | 09:06 AM
dwilson's Avatar
Default Re: Boost Controller Tuning (dwilson)
Anyone?
Old Jan 15, 2003 | 12:51 PM
dwilson's Avatar
ttt
Old Jan 23, 2003 | 09:48 AM
Smashback's Avatar
You should be able to turn it up a bit and not have to re-tune the Hondata at all. I started at 6, then 7, then 9, even at 15 (accidentally) my car ran fine with no adjustments and that was on the AFC hack, not the venerable Hondata.
90Rexx
Jul 26, 2010 10:16 PM
sevenj
May 25, 2008 01:15 PM
BlUAc
May 20, 2006 09:43 AM
freeplay
Sep 4, 2003 06:38 PM
RyanAutry
Nov 6, 2002 07:08 PM
