anyone running air to water IC?
what are the benefits over air to air? i was thinking a2w would provide for less pressure loss cuz you would have less piping right? also how do you feed the water for an a2w IC?
Re: anyone running air to water IC? (JeremyL)
depends on where its mounted and how you run the plumbing, but yes, there is the potential for less piping, and in turn less volume to pressurize. That wouldn't do anything for pressure loss, it'll just take a bit longer to pressurize the greater volume. Water is fed with an external pump.
Re: anyone running air to water IC? (1320development)
why would it be too much to deal with for a street car? if that means keeping a bottle filled i would have no problem with that since i pop my hood to check my oil EVERY time i get gas which is almost 2x/wk
i was under the impression u needed too keep cold *** water in there and that some people even use dry ice or something..so i was thinkin youd need too change it alottt during the day..keep the ice water flowin so it can cool...
New User
I run one in my daily driver... for about 2 years now... and I've NEVER had to change or add water. The system is a closed loop. The water doesnt ever leave. Because I live in a cold climate I have a 50/50 mix of water / coolant.
Also, contrary to popular belief the water does NOT get hot. If I hit the drags I can add ice to the tank to make things a little colder. Do some searches on this... It's been discussed quite a bit....
It can be a very good system and super efficient if you do it correctly. The only downfall is that it's more work to install since there are more pieces to the puzzle.
[Modified by MDA, 5:31 AM 1/16/2003]
Re: anyone running air to water IC? (MDA)
wow does the intercooler have too be somewhere where there is airflow too keep it cool?? or could i put it someplace in the engine bay??? also how is the cooling affect vs air too air??
New User
Re: anyone running air to water IC? (GOLDBERG)
The cooler itself is in the engine bay because it's soo small ... fits nicely inline with the charge pipe.
They are extremely efficient. I personally have an extra little cooler that ensures the water never gets warm... which it doesnt since water can absorb huge amounts of heat.
Goto Spearco's site, I'm sure they list the efficiency ratings and how they perform. I dont recall the numbers at the moment. When I was doing the research I was surprised more people dont use air-water. I think the reason is people like the huge intercooler that says, 'I'm turbo'd, don't mess with me'. Personally I like the low down look. Keep it a sleeper.
[Modified by MDA, 8:19 AM 1/16/2003]
well what attracts me even more is the space saving factor and the lack of charge piping needed to make it all work right, ill be removing my AC and all the lines along with my PS so i will have a lot more room in the bay to make everything fit
Good, Bad…I'm the one with the gun
Location: Trapped in time, Surrounded by evil, Low on gas
1 Post
That's great and all, just don't forget about the water pump, the heat exchange and piping.
stan
Yes the Vortech uses a A/W IC. It is a closed loop system, with it's own water pump, resevoir, and a heat exchange or radiator mounted in front of the A/C condensor.
Some have plumbed a cooling can inline, like ones drag racers use to cool fuel. This way the temp of the water/fluid in the A/W system can be cooled with out changing the water in the closed system; you can cool it by simply packing the cool can and then drain the cool can when not in use.
It works great for a track car.
Vortech's system behind the front bumper cover:
nevermind the crunched fender.
Re: anyone running air to water IC? (double0Si)
for a street car you could probably get by without a cooler since it would take a serious amount of heat to make the water in the IC lose its cooling capabilities
but even if you wanted to run a cooler which im assuming looks similar to the oil coolers and trany coolers on the market you probably wouldnt need to front mount it
by cooler, do you mean the heat exchange in the front or the cool can that I talked about.
I wouldn't run an A/W without a heat exchange.
The one that comes with the Vortech is exactly like some of the aftermarket oil coolers.
by cooler i meant the whole unit, but also i meant that would it be necessary to mount to the heat exchanger in the front by the bumper? probably not unless you live in Phoenix or Death Valley
if the water in the IC froze wouldnt it basically break the pump?
Re: anyone running air to water IC? (earl)
Earl has PWR come out with the pump and heat exchanger setup yet?..?
I have decided to run l2a on the street car.
Thanks!
Thanks!
