Golden Eagle VTEC Conversion Kit!
Old Jan 13, 2003 | 04:34 PM
X-Mazda 3 Racer's Avatar
Default Golden Eagle VTEC Conversion Kit!
Well, here she is. This our VTEC Conversion Kit. A very easy and sanitary way to add a VTEC head to a non VTEC block. Uses filtered oil for supply. Also has AN fitting for the head ( the correct metric thread ) so there is no stripping threads. All you need is to get a line made whatever length you need! It also has a port that can be used or a filtered turbo oil supply or pressure gauge sensor. Accepts the stock filter. Installs in less than 10 minutes. No drilling or cutting required. This is a very simple install and is a must for LS/VTEC or CR-VTEC engines or for anyone with a turbo!!! Call or e-mail us for prices. (909) 592 - 4311 or sales@goldeneaglemfg.com .
[Modified by GoldenEagleMfg.com, 3:04 AM 1/14/2003]
Old Jan 13, 2003 | 04:37 PM
khang77642's Avatar
Default Re: Golden Eagle VTEC Conversion Kit! (GoldenEagleMfg.com)
got pm
[Modified by khang77642, 7:38 PM 1/13/2003]
Old Jan 13, 2003 | 05:25 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Golden Eagle VTEC Conversion Kit! (khang77642)
hmm. maybe ill get in on one of those, post pics soon also, thanks
Old Jan 13, 2003 | 05:35 PM
AVATAR's Avatar
Default Re: Golden Eagle VTEC Conversion Kit! (SIXTYdashONE)
Sounds good! Hope the pricing is resonable.
Old Jan 13, 2003 | 05:43 PM
khang77642's Avatar
here you go
Old Jan 13, 2003 | 05:49 PM
Type Wah's Avatar
would this be compatible for my automatic teg? or would i need a new ecu? i might interested..
Old Jan 13, 2003 | 06:06 PM
Default Re: Golden Eagle VTEC Conversion Kit! (Type Wah)
You would need an ecu if you are converting to VTEC head, but this is just for the oil supply to the VTEC portion of the head.
Old Jan 13, 2003 | 06:15 PM
TheShocker's Avatar
You have mail.
Old Jan 13, 2003 | 06:18 PM
KOTSEMOTO's Avatar
I think thats about $60 each kit
Old Jan 13, 2003 | 06:27 PM
hybrid901's Avatar
Default Re: Golden Eagle VTEC Conversion Kit! (TheShocker)
Looks good
Old Jan 13, 2003 | 06:28 PM
HXMan's Avatar
YOu know what would be nice to go along with that?
The dowl pins FFGeoff was selling that make it possible to drop a VTEC head onto a non vtec block without changing any dowll holes!
Old Jan 13, 2003 | 06:36 PM
Savalicious's Avatar
works great vince thanks. just remember to plug the bottom of the vtec head before going to Harv's to dyno
Old Jan 13, 2003 | 07:02 PM
speeddave's Avatar
Default Re: Golden Eagle VTEC Conversion Kit! (quick1723)
could you run both for vtec head and for turbo feed? thanks... nice looking piece
[Modified by speeddave, 4:03 AM 1/14/2003]
Old Jan 13, 2003 | 07:05 PM
Default Re: Golden Eagle VTEC Conversion Kit! (speeddave)
Yes, that is what that other port is for. Either turbo oil feed or pressure sending unit sensor. It is a 1/4" NPT ( pipe thread ) and the Vtec port is a -6AN.
[Modified by GoldenEagleMfg.com, 5:22 PM 1/14/2003]
Old Jan 13, 2003 | 07:07 PM
Default Re: Golden Eagle VTEC Conversion Kit! (HXMan)
I will think about putting the dowles in with this kit. I forgot about those. I also will be able to supply you guys with the tap and plug for your head if you need it for a small amount of $, thanks for the reminder Sav!
Old Jan 13, 2003 | 07:11 PM
rondigs's Avatar
Man...I called you guys today and ordered my headgasket and head studs. The lady I talked to (?) mentioned a vtec conversion kit, but I figured she was talking about SS lines and what not.
I need one...
Old Jan 13, 2003 | 07:15 PM
Type Wah's Avatar
Default Re: Golden Eagle VTEC Conversion Kit! (rondigs)
how much does this kit cost?
Old Jan 13, 2003 | 07:26 PM
The Mole's Avatar
looks great man, whats the price and im probably down for one!!!!
-chris
Old Jan 13, 2003 | 07:45 PM
We will also have a kit that is complete with EVERYTHING you need very soon, but this is great for the do it yourselfer's!
Old Jan 13, 2003 | 07:46 PM
netnutshatch's Avatar
Default Re: Golden Eagle VTEC Conversion Kit! (The Mole)
Wow, looks great..... I'm definitely interested in one. You've got
Old Jan 13, 2003 | 07:51 PM
B18Flip's Avatar
Default Re: Golden Eagle VTEC Conversion Kit! (netnutshatch)
I'll be ordering mine manana
Old Jan 13, 2003 | 07:56 PM
SiRkid's Avatar
nice piece
Old Jan 13, 2003 | 10:13 PM
hondaswaper's Avatar
Default Re: Golden Eagle VTEC Conversion Kit! (SiRkid)
most people use a -6 line to feed the head, as the stock VTEC feed hole is 3/8th's
is there away to make yours a -6 ??
[Modified by hondaswaper, 11:14 PM 1/13/2003]
Rain_man's Avatar
New User
I can just plug up the vtec oil port if I don't want to use it correct? I need the oil feed line, but plan to do ls/vtec later, so...
Old Jan 13, 2003 | 10:15 PM
lucas569's Avatar
how come this doesnt have holes around it like other oil sandwhich adapters ive seen?
[img]www.we-todd-did-racing.com/wetoddimage.wtdr?i=wNDEwNDM2czQxM2RmZDMxeTU0MQ%3D% 3D[/img]
see the holes?
[Modified by lucas569, 2:19 AM 1/14/2003]
[Modified by lucas569, 2:22 AM 1/14/2003]
