engine management
Old Jan 14, 2003 | 12:26 AM
iwouldHITit's Avatar
Default engine management
is just having an inline pump and FMU good enough for 5-7 psi boost?? and what about for ignition??what if i only have sparkplug wires?? what do you guy recommand for my set up. ohh and the motor is a d16a6
Old Jan 14, 2003 | 12:32 AM
turbohonda's Avatar
Default Re: engine management (iwouldHITit)
You will be just fine with an inline pump and a 12-1 FMU for 5-7 psi. Also your ignition won't be a problem either. I would suggest just using the stock wires or a set of NGK's. Also maybe a set of spark plugs that are one heat range colder.
Old Jan 14, 2003 | 12:36 AM
Default Re: engine management (turbohonda)
thanks man...people where telling i need to get like an smc or afc...
Old Jan 14, 2003 | 12:45 AM
turbohonda's Avatar
An AFC is really only needed to "fine" tune your car and/or if you are running bigger injectors like 310's. Don't waste your time or money with the AFC, it is really not needed. IMO
Old Jan 15, 2003 | 03:28 PM
LbcJiGGa's Avatar
cool i needed that info also, thanks..
speedfoxracing
Feb 13, 2010 05:24 PM
eg6T
Oct 28, 2004 07:31 PM
boostincoupe
Sep 11, 2003 12:53 PM
turbofed EX
Sep 26, 2002 06:28 PM
sunscreen
Jul 3, 2002 08:57 PM
